If the engine has the timing hole ...
...and the timing cover and pulley are the same era as the engine, SSG is not going to find any marks or notches on the pulley and timing cover.
This is old school cool timing...but much more difficult in terms of seeing the timing marks. They are on the front of the flywheel...if the flywheel is original to this engine too. And if the flywheel was put on in the correct orientation.
The difficulty is...you need to be a bit of a contortionist to see and line up the timing marks.
You will
still need the woodruff key for your pulley, (Available at your local Ace Hardware), and you will still need to find TOP DEAD CENTER of the #1 cylinder.
