Author Topic: Help! 51 CJ3A  (Read 109243 times)
Offline SSG T
  • Hooah
Re: Help! 51 CJ3A
« Reply #165 on: April 07, 2015, 03:30:17 PM »
What do you think is up with the pump? Kt worked in the old motor before it blew
Re: Help! 51 CJ3A
« Reply #166 on: April 07, 2015, 03:51:36 PM »
Nice Work!
You have a working engine that is timed well enough to run. And a Carter WO that can deliver fuel.
Now, all other engine troubleshooting just got easier.
Offline CJPilot
  • Shade Tree Mechanic
Re: Help! 51 CJ3A
« Reply #167 on: April 07, 2015, 06:33:18 PM »
[size=12]Good news!  Why do you think there is a problem with the fuel pump?[/size]
Offline SSG T
  • Hooah
Re: Help! 51 CJ3A
« Reply #168 on: April 07, 2015, 06:45:47 PM »
[size=12]Good news!� Why do you think there is a problem with the fuel pump?[/size]
It wasnt sending gas to the carb. Seems to be working now. I will hopefully hook it back up to the carb tomorrow and see if I can. Keep the engine running.
As far as the starter/battery issue. Is there a ground that needs to go to the starter? Remember that ground on the fire wall I didn't know where it went? Wondering if that is the problem with having to use jumpers
Re: Help! 51 CJ3A
« Reply #169 on: April 07, 2015, 07:04:43 PM »
It would not hurt to hook that ground up again, though it's not original, it's there for a reason.......but since it's hooked to the body the body would then have to be well grounded.....
are there two cables there? A black one and a braided one?
Is the ground strap at the passenger side motor mount hooked up between the front engine plate and the frame? This is the normal way to ground the engine and starter to the frame.
You can just see it under the generator in this picture..
« Last Edit: April 07, 2015, 07:14:27 PM by 1955CJ-5 »
Re: Help! 51 CJ3A
« Reply #170 on: April 07, 2015, 07:16:36 PM »
The ground for the starter is accomplished with the ground strap from the engine to the frame.  This ground strap is usually found from the motor mount on the frame, to the front engine plate by the timing cover.
Because I know the critical nature of good grounds, I've added an additional ground cable as a back up. To some up...your battery grounds to the frame.  The frame needs to ground to the engine.  This completes the circuit to the starter when it's bolted to the engine.
I'll add...these ground points all need to be clean metal to clean metal.  Anything less than spotless ground connections and you will have a number of electrical issues.
For example, a portion of the surface between your starter mount and the rear engine plate that it mounts to, must be clean metal to clean metal.
Clean metal to clean metal.   Critical, critical, critical.
Some folks think I overstate my position. ;) ;D
Offline CJPilot
Re: Help! 51 CJ3A
« Reply #171 on: April 07, 2015, 07:20:08 PM »
[size=12]Here is another picture of the engine to frame ground strap.
Here is the negative battery cable.
You see how big a properly sized 6v battery cable is. They measure .450" diameter.[/size]
Offline SSG T
  • Hooah
Re: Help! 51 CJ3A
« Reply #172 on: April 07, 2015, 09:09:05 PM »
That must be my problem. there is no ground strap at all. 1955CJ-5 yes there is an original cable behind the black one. Where do you think i should hook it up too? Can i go to any auto store for that other ground?
Re: Help! 51 CJ3A
« Reply #173 on: April 07, 2015, 09:43:15 PM »
for now you could probably take both those grounds off the firewall..they are something that someone added....
and then use one of them as a temporary ground strap at the motor mount...they are a little long...you might tie a knot in it to shorten it and to keep it out of harms way...
A short strap with bolt holes in each end might be hard to find locally...I searched o'reillys and they had nothing...maybe try Napa?
This is what you are looking for...
http://walcks4wd.com/ground-strap-engine.html
« Last Edit: April 07, 2015, 09:50:16 PM by 1955CJ-5 »
Offline SSG T
  • Hooah
Re: Help! 51 CJ3A
« Reply #174 on: April 07, 2015, 11:07:19 PM »
For now i can use that original ground thats on the fire wall doing nothing. ill let you know how that works. I'll also check on the clutch and report back with that problem. What could i have done while installing the engine to make the clutch not work?
Offline SSG T
  • Hooah
Re: Help! 51 CJ3A
« Reply #175 on: April 08, 2015, 06:36:25 PM »
Just noticed oil all over the floor and found this. Where do I hook it up? Its on the driver side. The line to the right runs to the wiper
Offline CJPilot
Re: Help! 51 CJ3A
« Reply #176 on: April 08, 2015, 06:39:04 PM »
[size=12]That gets hooked up to the steel line right next to it.  It's the oil pressure gauge line.[/size]
Re: Help! 51 CJ3A
« Reply #177 on: April 08, 2015, 06:50:57 PM »
Offline SSG T
  • Hooah
Re: Help! 51 CJ3A
« Reply #178 on: April 08, 2015, 06:54:48 PM »
Thanks! She's running!!!! Gotta hook up the radiator now and the motor should be done right?!?
Offline CJPilot
Re: Help! 51 CJ3A
« Reply #179 on: April 08, 2015, 07:07:39 PM »
[size=12]Hey SSG T how about helping me out?
 How do you attach the mp4 files to your posts? [/size]
