Author Topic: Help! 51 CJ3A  (Read 109233 times)
Re: Help! 51 CJ3A
« Reply #135 on: April 03, 2015, 11:05:36 PM »
Okay, then you may have the older style engine.
Look at the second photo Ryan has posted.  This is showing the timing hole that can be found on the front face of the bell housing on the passenger side of the engine.  Down low.  It may have a small round cover over it...held on with one screw.  Try to find this.
Report back.
Offline SSG T
  • Hooah
Re: Help! 51 CJ3A
« Reply #136 on: April 03, 2015, 11:16:39 PM »
I see the window. Gonna have to call it a night and pick it back up tomorrow if I have time. Thanks for all the help. I'll post again soon
Offline SSG T
  • Hooah
Re: Help! 51 CJ3A
« Reply #137 on: April 03, 2015, 11:29:22 PM »
[size=12]The lower pulley can only go on one way because it's keyed to the crankshaft.
Once you have found #1TDC you can set the ignition timing.[/size]
The key you mentioned is not there! Is this a problem????
Offline CJPilot
  • Shade Tree Mechanic
Re: Help! 51 CJ3A
« Reply #138 on: April 04, 2015, 08:38:02 AM »
[size=12]
Yes that's a problem as far as using the lower pulley to set the timing and making sure the pulley doesn't slip while running the fan and generator.
It's called a woodruff key it sets the notch on the lower pulley to the proper clock position.  If you have the lower pulley off check it for a notch on the OD.  If you do find the notch put some white paint on it.  If you don't fin a notch post a picture of your lower pulley.
If the timing was set properly the omission of this woodrfuff key would not stop the engine from running.  [/size]
Re: Help! 51 CJ3A
« Reply #139 on: April 04, 2015, 10:00:00 AM »
If the engine has the timing hole ...
...and the timing cover and pulley are the same era as the engine, SSG is not going to find any marks or notches on the pulley and timing cover.
This is old school cool timing...but much more difficult in terms of seeing the timing marks.  They are on the front of the  flywheel...if the flywheel is original to this engine too.  And if the flywheel was put on in the correct orientation.
The difficulty is...you need to be a bit of a contortionist to see and line up the timing marks.
You will still need the woodruff key for your pulley, (Available at your local Ace Hardware), and you will still need to find TOP DEAD CENTER of the #1 cylinder.
Re: Help! 51 CJ3A
« Reply #140 on: April 04, 2015, 12:22:37 PM »
[size=12]Just about everything you didn't want to know about timing is right here; http://oldjeepcarbs.freeforums.net/board/35/timing[/size][/b]
Offline SSG T
  • Hooah
Re: Help! 51 CJ3A
« Reply #141 on: April 04, 2015, 02:01:56 PM »
Picked up the wife's new jeep compass today. Now I need to get a few of sleep hours before the 12 hr night shift but will try to get in the garage tomorrow. cjpilot your only a few hours away. How much to come out and learn me a thing or two? Haha. Hope to report back to you guys tomorrow. Thanks again for all the help!
« Last Edit: April 04, 2015, 02:03:13 PM by Taber12112 »
Offline CJPilot
Re: Help! 51 CJ3A
« Reply #142 on: April 05, 2015, 11:28:03 AM »
[size=12]Lack of timing marks does present a problem.� If you are working by yourself you aren�t going to be able to turn the engine over and check for compression at the same time.� You need something to thread into the spark plug hole and stick a balloon on that.� I used a Harbor freight cylinder leak down adapter.
Thread it in the #1 Cylinder and crank the engine over.�
The balloon will fill up on the compression stroke when it deflates stop turning the engine.� The engine should be just past #1 TDC.
 This is where my rotor was pointing when I my balloon was inflated the most.� You should be able to confirm #1TDC with the timing marks on the flywheel
[/size]
« Last Edit: April 05, 2015, 07:26:55 PM by CJPilot »
Re: Help! 51 CJ3A
« Reply #143 on: April 05, 2015, 03:45:43 PM »
[size=12]Genius[/size][/b]
Offline SSG T
  • Hooah
Re: Help! 51 CJ3A
« Reply #144 on: April 05, 2015, 09:17:57 PM »
Gonna be a few days before i can get some time in the garage. But i think this is getting way past my skills guys.
Offline SSG T
  • Hooah
Re: Help! 51 CJ3A
« Reply #145 on: April 05, 2015, 11:45:21 PM »
what about one of those timing lights?
Re: Help! 51 CJ3A
« Reply #146 on: April 06, 2015, 05:02:19 AM »
[size=12]Click the link. Use Sean's GEICO method to bring the timing in very close. Follow the instruction in the Setting the Timing without a Light segment and VOILA! the motor should be right on time. http://oldjeepcarbs.freeforums.net/board/35/timing[/size][/b]
Re: Help! 51 CJ3A
« Reply #147 on: April 06, 2015, 10:46:53 AM »
Failure is not an option Soldier! ;)
Many folks here...including myself...had zero experience working on cars.� Eventually, this will become second nature to you.
You can do this, but there is an order and process to messing with these things.� You can't start with step 4, then go back to step 1.  �
« Last Edit: April 06, 2015, 10:47:49 AM by athawk11 »
Re: Help! 51 CJ3A
« Reply #148 on: April 06, 2015, 11:20:50 AM »
I second what athawk says. If this forum could guide an imbecile like me through cobbling a Jeep back together we can certainly get you through it. Listen to what people are saying and do it in the order they are telling you to do things. This is a simple process with simple individual steps if done in order. Anything other than that and it's a jumbled overwhelming mess.
Re: Help! 51 CJ3A
« Reply #149 on: April 06, 2015, 12:13:05 PM »
Yes, do things in order as everyone has said..
To get to the end you must start at the beginning.....every story starts with page one....
