Author Topic: Help! 51 CJ3A  (Read 109211 times)
Offline CJPilot
  • Shade Tree Mechanic
Re: Help! 51 CJ3A
« Reply #105 on: April 02, 2015, 09:35:45 PM »
[size=12]
Has it been confirmed that the valve timing is correct, i.e. the timing dots lined up?
Another thought I had.  This is a geared engine so once you think you have found TDC you can check the timing marks on the front of the timing cover with the lower pulley.   They should be aligned when #1 is at TDC.  But be aware they will also be aligned when the #4 cylinder is at TDC.  That is why you need to feel the compression.
[/size]
Offline SSG T
  • Hooah
Re: Help! 51 CJ3A
« Reply #106 on: April 02, 2015, 09:57:41 PM »
Those wires seem pretty think and they worked before I blew the motor. I will try the timing again hawk and let you know asap. Pics coming soon
Offline SSG T
  • Hooah
Re: Help! 51 CJ3A
« Reply #107 on: April 02, 2015, 10:20:23 PM »
Pics
Offline SSG T
  • Hooah
Re: Help! 51 CJ3A
« Reply #108 on: April 02, 2015, 10:23:25 PM »
 Pic
Offline SSG T
  • Hooah
Re: Help! 51 CJ3A
« Reply #109 on: April 02, 2015, 10:24:22 PM »
pic
Offline SSG T
  • Hooah
Re: Help! 51 CJ3A
« Reply #110 on: April 02, 2015, 10:25:04 PM »
pic
Offline SSG T
  • Hooah
Re: Help! 51 CJ3A
« Reply #111 on: April 02, 2015, 10:26:15 PM »
pic
Offline SSG T
  • Hooah
Re: Help! 51 CJ3A
« Reply #112 on: April 02, 2015, 10:26:57 PM »
pic
Offline SSG T
  • Hooah
Re: Help! 51 CJ3A
« Reply #113 on: April 02, 2015, 10:27:41 PM »
pic
Offline CJPilot
Re: Help! 51 CJ3A
« Reply #114 on: April 02, 2015, 10:59:48 PM »
[size=12]I was looking for a picture that showed the plug wires from the distributor to the plugs.  That way we could see if the firing order was right. Your pictures don't show that.
And your right those battery wires do look like big wires.  I can't tell by the pictures what size your wires are, I'm just guessing. A 6v system draws twice the current a 12v system does for the same amount of work.  If your wires are not properly sized they will heat up and when they do they don't conduct as well and they get even warmer.  They work just not very well. Not a good situation when you are trying to start a cranky engine.
Your distributor is not in the "normal" clock position. Normally the clips are at the 3 and 9 o'clock position and the wire terminal is up.
The "normal" clock position for the #1 plug wire is the 5 o'clock position.
[/size]
Offline SSG T
  • Hooah
Re: Help! 51 CJ3A
« Reply #115 on: April 02, 2015, 11:10:14 PM »
I'll give the timing another go tomorrow and try shat you said. dumb question but....TDC stands for?
Offline SSG T
  • Hooah
Re: Help! 51 CJ3A
« Reply #116 on: April 02, 2015, 11:11:15 PM »
Here I go again skipping around... Still don't have the fuel pump working
Re: Help! 51 CJ3A
« Reply #117 on: April 02, 2015, 11:13:05 PM »
Top� Dead� Center....TDC
It means that the #1 piston is at the very top of it's compression stroke.....ignition timing is set 5� before TDC to provide spark as the piston arrives at TDC
And both the intake and exhaust valves are fully closed for the full compression stroke...
https://www.youtube.com/watch?v=Gvleh-Xt2VU
« Last Edit: April 02, 2015, 11:16:49 PM by 1955CJ-5 »
Offline CJPilot
Re: Help! 51 CJ3A
« Reply #118 on: April 02, 2015, 11:21:51 PM »
[size=12]Why would you dump a bunch to fuel into the engine before the ignition timing was straightened out?
I might add that the timing does not have to be in the �normal� clock position in order to run correctly.  It just helps   to make sense of everything.[/size]
« Last Edit: April 03, 2015, 07:06:05 AM by CJPilot »
Offline CJPilot
Re: Help! 51 CJ3A
« Reply #119 on: April 03, 2015, 07:27:11 AM »
[size=12]Firing order at the distributor.  And shown in the "normal" position[/size]
