Author Topic: Help! 51 CJ3A  (Read 109234 times)
Re: Help! 51 CJ3A
« Reply #120 on: April 03, 2015, 10:32:34 AM »
[size=12]
I might add that the timing does not have to be in the �normal� clock position in order to run correctly.� It just helps� �to make sense of everything.[/size]
Excellent point.  This is why I'm looking for the basics.  If we know where his rotor is pointing when the #1 piston is at TDC...(Top Dead Center), we can start to help him time his engine.
SGG, Once we know some of these basics, we'll help you, but we need focus! ;)  Timing an engine is a step by step procedure.  We are trying to guide you in the steps we have all found to work.
You have the hottest thread going on the 3A Page right now.  That's because we all want you to be successful.
Offline SSG T
  • Hooah
Re: Help! 51 CJ3A
« Reply #121 on: April 03, 2015, 08:30:01 PM »
Does this sound like I got the timing guys?
Offline SSG T
  • Hooah
Re: Help! 51 CJ3A
« Reply #122 on: April 03, 2015, 08:39:13 PM »
Like this correct??
Offline SSG T
  • Hooah
Re: Help! 51 CJ3A
« Reply #123 on: April 03, 2015, 08:54:11 PM »
haha Hawk its the hottest because I need the most help! I went into this not knowing much and have come out learning more then I ever thought! glad I didn't sell it when I blew the motor. I have all you to thank. Hopefully I can get her running for the summer!
Offline CJPilot
  • Shade Tree Mechanic
Re: Help! 51 CJ3A
« Reply #124 on: April 03, 2015, 09:07:29 PM »
[size=12]The firing order looks ok to me.  But the distributor is not in the  "normal" clock position.  You should find out why.  Do you have a shop manual you can reference?  The CJ3a has timing marks on the flywheel and on the front of the engine.  Are you familiar with them?[/size]
Offline SSG T
  • Hooah
Re: Help! 51 CJ3A
« Reply #125 on: April 03, 2015, 09:12:43 PM »
it was in the clock position but then the number 1 plug was at 1 o'clock so I turned the distributor back to have it at 5 o'clock
Offline CJPilot
Re: Help! 51 CJ3A
« Reply #126 on: April 03, 2015, 09:42:40 PM »
[size=12]You are making this all harder that it really is.
* Pull the plugs out
* Hold finger on #1 cylinder plug hole and turn engine by hand until the compression blows your finger from the cylinder
* You should be close to #1 TDC
* Find the timing marks on the front on the engine and rotate the engine by hand a small amount to line the timing marks up.
* You should now be at #1TDC  Don't turn the engine until you have set the ignition timing
* Take off the distributor cap.  Take a picture of the rotor position and post it.
* The rotor should be pointing to the #1 plug wire.
[/size]
Offline SSG T
  • Hooah
Re: Help! 51 CJ3A
« Reply #127 on: April 03, 2015, 09:50:04 PM »
The timing marks on the gears? And should I set the clips back to 9 and 3 o'clock then do all that
« Last Edit: April 03, 2015, 10:03:04 PM by Taber12112 »
Re: Help! 51 CJ3A
« Reply #128 on: April 03, 2015, 10:07:13 PM »
Offline CJPilot
Re: Help! 51 CJ3A
« Reply #129 on: April 03, 2015, 10:13:57 PM »
[size=12]The ignition timing marks are;
A line on the timing cover
� �� �� � and
A notch in the lower pulley
(see Ryan's picture above)
When the engine is making compression in the #1 cylinder (finger blown away from plug hole) and the timing marks are line up the engine is at #1 TDC
Please leave the distributor alone until you find out what you need to do with it.
[/size]
« Last Edit: April 03, 2015, 10:26:13 PM by CJPilot »
Offline SSG T
  • Hooah
Re: Help! 51 CJ3A
« Reply #130 on: April 03, 2015, 10:18:43 PM »
Ohhh OK good. BUT could I have put that lower pully on wrong by chance?
Offline CJPilot
Re: Help! 51 CJ3A
« Reply #131 on: April 03, 2015, 10:23:20 PM »
[size=12]The lower pulley can only go on one way because it's keyed to the crankshaft.
Once you have found #1TDC you can set the ignition timing.[/size]
Re: Help! 51 CJ3A
« Reply #132 on: April 03, 2015, 10:38:31 PM »
Listen to the Pilot, Sarge!
Step 1:  Find...Top Dead Center at cylinder #1!!!
Use the approach we have suggested.
Then, we can move forward.
Offline SSG T
  • Hooah
Re: Help! 51 CJ3A
« Reply #133 on: April 03, 2015, 10:43:28 PM »
I'm sorry but I don't see any kind of marks on the timing cover. I did make sure to line up the dots on the gears when I put the motor mount plate on. Previous mount plate was bent
« Last Edit: April 03, 2015, 10:47:40 PM by Taber12112 »
Offline CJPilot
Re: Help! 51 CJ3A
« Reply #134 on: April 03, 2015, 10:58:22 PM »
[size=12]OK lucky for you there are timing marks on the flywheel.  They are on the passenger side inside of a small hole that has a cover over it. See Ryan�s picture above.  I�ll warn you though; they are harder to work with.  In any event you HAVE to find #1TDC to get this thing running.
Not finding #1TDC = not running :(
[/size]
