I just watched the video again about 20 times on a larger screen. I change my opinion and agree with SSG - I don't think those are sparks. It's fuel blowing out either around the carb gasket or some lower parts of the carb where it shouldn't be, Still not good, but not as close to an explosion as I initially feared.
Edit: Is the carb bolted tightly to the manifold? If so, can you see where the fuel is coming from? I'm wondering if the thing is just completely flooded in that video and the intake manifold is full of fuel. Have you figured out if the timing is set reasonably close?
