Author Topic: Help! 51 CJ3A  (Read 109192 times)
Offline BMIC
  • Weekend Mechanic
Re: Help! 51 CJ3A
« Reply #60 on: March 17, 2015, 01:04:16 PM »
SSG T .... Sad to read your last post, all the best to you and family.
Re: Help! 51 CJ3A
« Reply #61 on: March 17, 2015, 08:00:43 PM »
I hope she's okay.  Check back in when you get a chance.
Offline SSG T
  • Hooah
Re: Help! 51 CJ3A
« Reply #62 on: March 25, 2015, 03:13:08 PM »
Thanks guys. Shes going to be ok but will have a long recovery. I've been able to sneak away to the garage when someone comes to visit and you wont beleieve it but i got her to start for a few seconds! distributor wasnt set in like you guys said. Still need to play with the timming but with any luck shell be running good soon. Now for the new problem. Clutch doesnt work! >:( ! i push it to the floor and it has no resistance at all. i never did anything with the clutch when i took out the old motor and everything looked good on it when i put the new motor in. any ideas?
Re: Help! 51 CJ3A
« Reply #63 on: March 25, 2015, 03:26:56 PM »
It's good to hear that your wife will be OK....
Is your inspection cover on the bell housing accessible? I can't remember if your tub is on or off....
If you can take the inspection cover off you can check for movement of the pressure plate...
If the pedal arm-to-frame return spring is not installed the clutch will feel very light....the spring runs from the pedal arm to the body mount just under the drivers floor, along the outside of the frame.
Offline SSG T
  • Hooah
Re: Help! 51 CJ3A
« Reply #64 on: March 25, 2015, 04:23:40 PM »
inspection cover is on, so is the tub.
Re: Help! 51 CJ3A
« Reply #65 on: March 25, 2015, 05:32:30 PM »
Good to hear she's doing okay.
Could the clutch cable have come loose from the clutch fork?  This is all inside the bell housing, so it's going to be hard to see. You might be able to tell by pulling on the clutch cable to see if you feel tension and spring back.  You can find this cable connected to the clutch linkage, then traveling in to the bell housing, below the driver seat.
Offline SSG T
  • Hooah
Re: Help! 51 CJ3A
« Reply #66 on: March 31, 2015, 08:26:07 PM »
Alright guys. I need to stop jumping around and do things in order! New problem I found is its not getting gas. I original thought this line was a over flow but maybe not.... I have 3 gas lines coming from the fuel pump. On goes to the carb the other to the manifold. Where does the third one go? Was I right and its an over flow? Thanks for the help!!
Re: Help! 51 CJ3A
« Reply #67 on: March 31, 2015, 08:37:20 PM »
Sounds like you have a fuel pump with a vacuum booster? If so, the upper two fittings are for fuel. One is IN from the fuel tank line and one is OUT to the carb.
The lower two fittings are IN from the intake manifold and OUT to the vacuum wipers if equipped.
If your pump does not have the vacuum booster there should only be two lines. IN from the tank line and OUT to the carb
Re: Help! 51 CJ3A
« Reply #68 on: March 31, 2015, 08:39:36 PM »
If you have the original style fuel pump, there will be four lines connected to it.
One coming in from the fuel tank.
Another going to the carburator.
These are the only lines that carry fuel.
The other lines help boost vacuum to the original windshield wiper motors.
One would be attached to the manifold.
The other would go all the way to the wiper motor.
Offline SSG T
  • Hooah
Re: Help! 51 CJ3A
« Reply #69 on: March 31, 2015, 08:46:12 PM »
I'll send pics in a few for your Tim
Offline SSG T
  • Hooah
Re: Help! 51 CJ3A
« Reply #70 on: March 31, 2015, 09:23:01 PM »
So is this right? The top line on the fuel pump goes to the carb the one below that goes to manifold and the one on the right goes to the wiper? And the wiper is not hooked up. Would that cause the pump not to get gas to the carb?
Offline SSG T
  • Hooah
Re: Help! 51 CJ3A
« Reply #71 on: March 31, 2015, 09:28:11 PM »
My bet is the one below the top should go to the manifold but i have it going now where. Here's another pic so you know what I mean by top bottom and right
B=bottom
T=top
R=right
Re: Help! 51 CJ3A
« Reply #72 on: March 31, 2015, 10:12:54 PM »
This appears to be the original style dual action pump.  The top two connections are fuel in and fuel out.
The lower two are vacuum lines.  The line that isn't connected would have originally pointed in the other direction.  It leaves the engine compartment through the large hole on the side of the driver side cowl.  It travels to the wiper motor.
It probably isn't connected if you don't have the original style vacuum wiper motor....
You can see the tube below the windshield arm in the photo...
Re: Help! 51 CJ3A
« Reply #73 on: March 31, 2015, 10:18:55 PM »
To answer your question, the disconnected line would not affect you fuel pump from delivering fuel to the carb.  If the vacuum line is not plugged up, it would basically be a vacuum leak...which will cause the engine to run poorly...if at all.
Re: Help! 51 CJ3A
« Reply #74 on: March 31, 2015, 10:21:28 PM »
Plug the end of that line that is supposed to go to the windshield wiper....
right now it is just a vacuum leak....
when you finally get it hooked up to the wiper motor then that will effectively be a plug....
but that will have nothing to do with whether or not the fuel pump portion will work...
you need a couple inches of fuel in the tank before it will draw fuel as there is a stand-off in the tank...
Edit...Tim types quicker than I do!
« Last Edit: March 31, 2015, 10:22:42 PM by 1955CJ-5 »
