Author Topic: Help! 51 CJ3A  (Read 109178 times)
Offline SSG T
  • Hooah
Re: Help! 51 CJ3A
« Reply #45 on: March 13, 2015, 07:08:28 PM »
Or, the cam and oil pump gears are not meshing and the oil pump is not turning....
Even if it's shot/worn it ought to turn...
Can you post pictures?� I'm not sure what you mean by the braided ground wire....
I just did, Does the picture show up for?
Re: Help! 51 CJ3A
« Reply #46 on: March 13, 2015, 07:09:17 PM »
I see the wire now..our posts crossed in the mail!
Somebody has added that.....maybe they used it to ground the engine?  There should be a ground strap near the right front motor mount, from the frame to the engine plate.
Offline SSG T
  • Hooah
Re: Help! 51 CJ3A
« Reply #47 on: March 13, 2015, 07:16:10 PM »
Yes, that ground strap by the motor mount is good. if you look close you can see the old braided ground behind the new added one. leads me to believe that should be there.
Re: Help! 51 CJ3A
« Reply #48 on: March 13, 2015, 07:23:54 PM »
SSG,
Did your friend pull the oil pump out of the block too?
All above info is dead on.  Inspect the "key" on the distributor shaft.  It might have some burrs that won't let it slip fit into the oil pump slot correctly.  If so, just dress the edges with a file.  Don't go crazy.  Just enough to get it to fit in to the slot.
Re: Help! 51 CJ3A
« Reply #49 on: March 13, 2015, 07:25:43 PM »
I don't know what else is behind that firewall but if it were me and you have all stock gauges and ignition I would wire it up exactly as it should be in stock form. Eliminate all the mystery add-ons and you'll have fewer variables to deal with.
The wiring on these is very simple. I'm utterly numb on all things wiring and I was able to get a couple to run. If I can do it anyone can pull this off.
Re: Help! 51 CJ3A
« Reply #50 on: March 13, 2015, 07:31:33 PM »
Well, first what I would do is make sure the rotor is fitted to the distributor shaft correctly. there is a flat side to the shaft and a corresponding flat inside the rotor. It should be a snug fit.
If the rotor is tight on the shaft, try to rotate the shaft and rotor together by hand. If they turn freely then the dist tab probably is not fitting into the oil pump slot....it can be a snug fit if the little anti-rattle clip is on the end of the distributor shaft...and the oil pump slot is off center so the distributor will only fit one way.
If you are able to turn the rotor by hand and it is really tight or if you hear noises inside the engine, there may be other issues...
Offline SSG T
  • Hooah
Re: Help! 51 CJ3A
« Reply #51 on: March 13, 2015, 07:33:32 PM »
Hey Tim,
No he did not pull off the oil pump. I'll pull the whole thing out and check it over. found a distributor for $10 local. might pick that up and try it if none of this works. its for a 2A tho, would it still work?
Re: Help! 51 CJ3A
« Reply #52 on: March 13, 2015, 07:57:34 PM »
SSG,
Don't pull the oil pump!� Not just yet.
I was hoping your friend left it alone. If not done correctly, pulling, then resetting an oil pump can cause additional issues we don't want to have just yet. It would just complicate what we're all trying to do right now...get this running.
As the others have suggested, over a 65 year life span, wires and components have come and gone. You are likely to find a bunch of stragglers that do nothing...and go no where.� (we all have)
The cable you are holding in your hand may have gone to a starter solenoid, then down to your starter. Your starter looks new...and correct for a 3A, so my guess is that cable got let behind when your Willys was fixed up at some point.
Let's get your Distributor spinning, then start messing with other stuff. :)
« Last Edit: March 13, 2015, 07:58:39 PM by athawk11 »
Offline SSG T
  • Hooah
Re: Help! 51 CJ3A
« Reply #53 on: March 13, 2015, 08:14:32 PM »
SSG,
its the original starter, just had it rebuilt ( Nice $190 bill)
Re: Help! 51 CJ3A
« Reply #54 on: March 13, 2015, 09:25:35 PM »
How hard does the engine turn over by hand with the spark plugs out? I am suspecting the engine bearings or rings are to tight.
Offline SSG T
  • Hooah
Re: Help! 51 CJ3A
« Reply #55 on: March 13, 2015, 10:09:46 PM »
Turns over good i think. Not loose enough to so with out a wrench
Re: Help! 51 CJ3A
« Reply #56 on: March 14, 2015, 08:43:13 AM »
Carl,
If you go back and read the posts, you'll see he's solved the slow turning issue.
Offline p3ferris
Re: Help! 51 CJ3A
« Reply #57 on: March 16, 2015, 10:38:50 PM »
Pull the starter out and check it
Offline SSG T
  • Hooah
Re: Help! 51 CJ3A
« Reply #58 on: March 17, 2015, 07:17:10 AM »
Sorry guys but the Willys is on hold. My wife had a bad car accident and i have been in the hospital since Friday. Will pick up where I left off in a few weeks.
Re: Help! 51 CJ3A
« Reply #59 on: March 17, 2015, 07:22:40 AM »
Oh no, hope all is well, my thoughts and prayers are with you.
