Author Topic: Help! 51 CJ3A  (Read 109191 times)
Offline SSG T
  • Hooah
Re: Help! 51 CJ3A
« Reply #75 on: March 31, 2015, 10:35:57 PM »
How can I be sure the fuel pump isn't working? Would this vacume leak be the reason I can only get the motor to run while holding the starter? As soon as I let off the starter it dies. Also timing isnt right. Any videos on how to set timing out there you know of?
Re: Help! 51 CJ3A
« Reply #76 on: March 31, 2015, 10:37:26 PM »
No...
There is an upper diaphragm in the pump for fuel, and a lower diaphragm for air. It is really two pumps in one housing....only the actuating lever is common to both..
Re: Help! 51 CJ3A
« Reply #77 on: March 31, 2015, 10:40:30 PM »
This is a good explanation of checking and setting the timing..
http://www.thecj2apage.com/forums/topic13819_post115561.html#115561
« Last Edit: March 31, 2015, 10:41:38 PM by 1955CJ-5 »
Offline SSG T
  • Hooah
Re: Help! 51 CJ3A
« Reply #78 on: March 31, 2015, 11:11:38 PM »
Would this vacuum leak be the reason I can only get the motor to run while holding the starter? As soon as I let off the starter it dies.?!?!?!
Here is a good video if anyone else needs help with timing
Walck's Distributor.m4v: https://youtu.be/il7nKhbjwVo
Re: Help! 51 CJ3A
« Reply #79 on: March 31, 2015, 11:16:55 PM »
Excellent link Randy.  That explanation was what finally helped me understand it all.
SSG, when you say..."have to hold the starter to keep it running", are you holding the key in the "start" position?  If so, you might not have the key switch wired correctly.
Also, to check the fuel pump, disconnect the fuel line at the carburator.  Stick a sandwich bag over the end, then turn the engine.  If fuel flows into the bag, your fuel pump is pumping.
Offline SSG T
  • Hooah
Re: Help! 51 CJ3A
« Reply #80 on: April 01, 2015, 07:50:31 AM »
Tim,
I have the original foot starter. So I have to push and hold it and it runs but doesnt stay running when i let off.  Could this be because of the vacuum leak?
« Last Edit: April 01, 2015, 07:51:43 AM by Taber12112 »
Re: Help! 51 CJ3A
« Reply #81 on: April 01, 2015, 10:24:30 AM »
Plug the leak and see if that helps...
I think you may be dealing with a combination of problems and you need to solve each one, one at a time.
Carefully set the ignition timing.
Get reliable fuel flow to the carburetor.
« Last Edit: April 01, 2015, 10:47:34 AM by 1955CJ-5 »
Re: Help! 51 CJ3A
« Reply #82 on: April 01, 2015, 11:31:36 AM »
I agree with 1955CJ-5...  Get some of these minor issues worked out, then move to the next.  Jumping around might cause confusion for us helpers...and you.
It�s hard to tell what might be affecting your start and run condition over the internet, but there are a few things that can cause trouble.
A vacuum leak is more of a mechanical issue.  You don�t want vacuum leaks.  I would plug the tube to eliminate this from being an issue.  Do you have the vacuum wiper motor shown in the above photo?
There are two different electrical circuits that need to be connected correctly.  A start circuit and an ignition/run circuit.  If you have to hold the foot start to keep it running, these two circuits are not wired correctly.
I�m just not entirely sure how your starter can be engaged while the engine is running.  I would refrain from doing this until we get some electrical connections figured out.
Tell us about your key switch.  You have an �off� position.  One click to the right will be the �ignition� position.  Is that it?  Or can you turn the key one more notch to the right that will spring back?
Offline CJPilot
  • Shade Tree Mechanic
Re: Help! 51 CJ3A
« Reply #83 on: April 01, 2015, 01:17:13 PM »
How about removing the wire(s) from the pos side of the coil and running a jumper from the Battery to the pos side of the coil?  That would eliminate any ignition wiring issues as you try to figure out what your problem is.  You would need to disconnect this wire in order to stop the engine.
Others may know better but I don�t think a vacuum leak at the combo fuel and vacuum pump will cause any kind of engine running problem.
Offline SSG T
  • Hooah
Re: Help! 51 CJ3A
« Reply #84 on: April 01, 2015, 06:38:56 PM »
Excellent link Randy.� That explanation was what finally helped me understand it all.
SSG, when you say..."have to hold the starter to keep it running", are you holding the key in the "start" position?� If so, you might not have the key switch wired correctly.
Also, to check the fuel pump, disconnect the fuel line at the carburator.� Stick a sandwich bag over the end, then turn the engine.� If fuel flows into the bag, your fuel pump is pumping.�
No go Tim. Pulled the line off and its not shooting out gas.
Re: Help! 51 CJ3A
« Reply #85 on: April 01, 2015, 07:33:25 PM »
Your thread started by explaining that you had blown up the previous engine...do you still have it and does it have a fuel pump on it that works?
Is the fuel tank clean?
Is there fuel in it? How Much?
Is the fuel line from the tank to the pump clear and will fuel flow through it?
If you put your finger over the line that attaches from the pump to the carb can you feel air pressure while cranking the engine?
That metal cap with the single center bolt will come off your fuel pump and there is a fine mesh filter screen underneath. You might check it to see if is clean...
If all else fails you can get a single action fuel pump at most auto stores...it will not have the vacuum portion..it's really a 2a pump. But I think they are less that $50 and they work fine if you don't want to pay for an original style pump.
From the looks of it your current fuel pump is an original...DON'T THROW IT AWAY!!...you ought to be able to get a kit from Walck's to rebuild it....It's probably an AC 9562 but the number will be stamped on the mounting flange.
« Last Edit: April 01, 2015, 07:43:00 PM by 1955CJ-5 »
Offline SSG T
  • Hooah
Re: Help! 51 CJ3A
« Reply #86 on: April 01, 2015, 08:08:12 PM »
So the wiper is not original. Its electronic. I can try to put a tube on the fuel line to the tank and see if I van suck the gas.( will probably end up with some tasty gas. If gas comes I know its the fuel pump...correct?
Re: Help! 51 CJ3A
« Reply #87 on: April 01, 2015, 08:34:24 PM »
Maybe you should first blow through it and see if you hear it bubbling in the tank....
Re: Help! 51 CJ3A
« Reply #88 on: April 01, 2015, 08:50:43 PM »
Agreed.  These old tanks and fuel lines are notorious for developing clogs.  Especially if the Willys has been sitting for an extended length of time.
tim
Offline SSG T
  • Hooah
Re: Help! 51 CJ3A
« Reply #89 on: April 01, 2015, 09:03:48 PM »
Alright men, I'll try to get at it tomorrow. Going to look at cars for the old lady,  looks like a jeep patriot or nissian rouge here a pic of her car by the way! Very lucky girl. Thanks for all the help
