Good to hear she's doing okay.
Could the clutch cable have come loose from the clutch fork? This is all inside the bell housing, so it's going to be hard to see. You might be able to tell by pulling on the clutch cable to see if you feel tension and spring back. You can find this cable connected to the clutch linkage, then traveling in to the bell housing, below the driver seat.
