Author Topic: Help! 51 CJ3A  (Read 109224 times)
Re: Help! 51 CJ3A
« Reply #90 on: April 01, 2015, 09:15:22 PM »
Holy crap!  She must have had a guardian angel.
Offline SSG T
  • Hooah
Re: Help! 51 CJ3A
« Reply #91 on: April 02, 2015, 04:22:05 PM »
OK air went in the gas tank. So something is up with the fuel pump. Also check out this video.
Re: Help! 51 CJ3A
« Reply #92 on: April 02, 2015, 04:41:51 PM »
YOU NEED TO FIND OUT WHAT IS CAUSING THOSE SPARKS AND ARCING OR YOU WILL HAVE A FIRE...DO NOT TRY TO START IT AGAIN!
You are lucky the fuel pump isn't working or you would surely have a fire or explosion or both....
You need to get someone to help you trace that electrical problem....or take it to a repair shop....
Re: Help! 51 CJ3A
« Reply #93 on: April 02, 2015, 04:51:52 PM »
x2. That was close to being one of the most spectacular videos we all have ever seen. I'm glad it wasn't though.
Sparks and fuel....not so good outside of the engine....
Offline SSG T
  • Hooah
Re: Help! 51 CJ3A
« Reply #94 on: April 02, 2015, 04:55:50 PM »
I didn't see any sparks. I saw mist of gas coming from the bottom of the carb
Re: Help! 51 CJ3A
« Reply #95 on: April 02, 2015, 07:14:06 PM »
I was seeing fuel, arcs and sparks.  I'm miffed.  Is that a static discharge?  What could cause that at the base of the carb?
Offline SSG T
  • Hooah
Re: Help! 51 CJ3A
« Reply #96 on: April 02, 2015, 07:24:02 PM »
I'm about to throw in the towel guys. This sucks. I don't remember seeing any sparks tho. Could it be the mist hitting the sun light? Tempted to turn the lights off and try it again
« Last Edit: April 02, 2015, 07:28:29 PM by Taber12112 »
Re: Help! 51 CJ3A
« Reply #97 on: April 02, 2015, 07:38:20 PM »
I just watched the video again about 20 times on a larger screen. I change my opinion and agree with SSG - I don't think those are sparks. It's fuel blowing out either around the carb gasket or some lower parts of the carb where it shouldn't be, Still not good, but not as close to an explosion as I initially feared.
Edit: Is the carb bolted tightly to the manifold? If so, can you see where the fuel is coming from? I'm wondering if the thing is just completely flooded in that video and the intake manifold is full of fuel. Have you figured out if the timing is set reasonably close?
« Last Edit: April 02, 2015, 07:46:18 PM by Ryan_M »
Offline CJPilot
  • Shade Tree Mechanic
Re: Help! 51 CJ3A
« Reply #98 on: April 02, 2015, 07:44:53 PM »
[size=12]Maybe the firing order/ timing is causing a plug to fire while an intake valve is open.  That would explain the popping sound if there is in fact no sparks flying.  I see a reflection from in back of the carburetor as the accelerator is actuated after the engine stops turning.
So have you looked at the position of the rotor when the engine is at Top Dead Center for #1?  It should point to the #1 wire.  If you have confirmed all this  look else where.[/size]
Offline CJPilot
Re: Help! 51 CJ3A
« Reply #99 on: April 02, 2015, 07:50:37 PM »
Is this jeep 6v or 12v?  The wire gauge you have on the starter is for 12v. 6v needs a bigger wire.
Can you post a few picture showing the top of the distributor and where the wires run?
Offline SSG T
  • Hooah
Re: Help! 51 CJ3A
« Reply #100 on: April 02, 2015, 08:04:32 PM »
6v and I'm almost certain I screwed up the timing. And yes it was completely flooded. I blew the gas out of the carb with an air compressor. I turned the engine over till I felt pressure and stopped. Then put the number one plug there. The went counter clockwise with the rest of the plugs. The plugs are 1-4 starting st the front. correct? I know its gas shooting out the bottom of the carb. Yes its tight. Need a new gasket?
Offline SSG T
  • Hooah
Re: Help! 51 CJ3A
« Reply #101 on: April 02, 2015, 08:06:57 PM »
I'll send pics of the motor and distributor  and also, the motor came with an alternator. I used my old generator because the start is 6v
Offline CJPilot
Re: Help! 51 CJ3A
« Reply #102 on: April 02, 2015, 08:36:27 PM »
[size=12]It will not turn over properly with those battery cables. Walcks sells the right ones for 6v.  You need a larger dia wire because the 6v starter will draw more current than a 12v starter.
Is the coil you are using 6v?
You need to be absolutely positive you are finding TDC on the #1 cylinder.  Once you have that look at the rotor it should be pointing to the #1 spark plug wire.  If you want to get fancy make sure the points are just opening by rotating the distributor.  A trick is to leave the distributor clamp bolt just loose enough so that you can turn the distributor but it won�t turn on it�s own.  Once you have it running right tighten the clamp bolt.
After you have the #1 wire location on the distributor set, the rest of the wires can be put on one at a time.  The distributor turns counter clockwise.  The firing order is 1-3-4-2 so the next wire is the #3 cylinder, and so on. The cylinders themselves are numbered 1-2-3-4 starting from the front of the engine.
When you go to start it you will most likely need to turn the distributor a little in order to get it to start.  Once it starts slowly rotate the distributor in order to get the engine to run decent.  You can get more precision  with a timing light afterwards
[/size]
Re: Help! 51 CJ3A
« Reply #103 on: April 02, 2015, 08:47:10 PM »
OK maybe I freaked out.....
I think your valve timing is off and it's blowing back through the carb....
Very early on you mentioned not being able to find the timing dot on the cam gear....but you counted the teeth....
"Also found the dot by counting teeth on pics that show it"
I'm really glad I was wrong!
« Last Edit: April 02, 2015, 08:49:31 PM by 1955CJ-5 »
Re: Help! 51 CJ3A
« Reply #104 on: April 02, 2015, 09:02:17 PM »
Okay, good advice above.
Lets start at the beginning...
To find Top Dead Center... (or very close)
Take out the spark plug in the #1 position.� (First plug toward the front of the Willys).� Put a wrench on the pulley nut. (Large Pulley--lower front of engine) Use your thump to plug the #1 spark plug hole.� Hand turn the engine.� You will eventually feel air pressure against your thumb.� (This is the compression stroke in the #1 cylinder.)� Keep turning until the air pressure stops.
Now, take off your distributor cap.� Using a clock as a diagram, what time is the rotor pointing at?�
« Last Edit: April 02, 2015, 09:03:24 PM by athawk11 »
