Author Topic: Help! 51 CJ3A  (Read 109291 times)
Offline SSG T
  • Hooah
Re: Help! 51 CJ3A
« Reply #150 on: April 06, 2015, 03:30:02 PM »
OK guys. I took the starter out and cleaned the fly wheel. Found the marks and have it lined up.felt thd pressure on my finger when it lined up. This is where the rotor is at.  What now!?!
« Last Edit: April 06, 2015, 03:55:08 PM by Taber12112 »
Offline SSG T
  • Hooah
Re: Help! 51 CJ3A
« Reply #151 on: April 06, 2015, 03:40:33 PM »
Does  the notch need to be face straight up?
Re: Help! 51 CJ3A
« Reply #152 on: April 06, 2015, 04:39:46 PM »
Alright! Progress! Put your distributor cap on and put the #1 plug wire in the 5 o'clock location where your rotor is. Then connect plug wires 3-4-2 going counter clockwise. That timing notch on the pulley looks correct (approx 11 o'clock position) but tough to tell if you don't have a mark on the timing cover.
At least now we know your timing is somewhere in the ball park. I'd make sure the carb gasket is good and the carb torqued down and take another crack at starting it. We still have to confirm your points are gapped correctly but you might as well try and crank it over.
Edit: Is that the mark on the timing cover I see? I think it is but tough to tell from the pic. If it is it looks good.
« Last Edit: April 06, 2015, 04:44:28 PM by Ryan_M »
Offline SSG T
  • Hooah
Re: Help! 51 CJ3A
« Reply #153 on: April 06, 2015, 06:18:43 PM »
So to clear things up, the rotor is in the 5 o'clock position now? i will try to fire it up tomorrow and let you know what happens.
Offline dat
Re: Help! 51 CJ3A
« Reply #154 on: April 06, 2015, 06:28:54 PM »
I'm ready to hear that thing crank up
Re: Help! 51 CJ3A
« Reply #155 on: April 06, 2015, 06:51:18 PM »
It looks like 5 O'clock to me....Good work!
Do you know how to check the point gap?
It should be .020" when the points are open....you need a feeler gauge to check it and a flat blade screwdriver to adjust
This may help...it even looks like a Willys!  But i think his distributor is 180� off but the idea is the same...
https://www.youtube.com/watch?v=fX0tDVmoEI8
« Last Edit: April 06, 2015, 07:00:36 PM by 1955CJ-5 »
Offline CJPilot
  • Shade Tree Mechanic
Re: Help! 51 CJ3A
« Reply #156 on: April 06, 2015, 08:50:16 PM »
[size=12]You are now on the right track to getting that thing to run. ;D
If you are in fact at #1TDC then the oil pump gear was installed in the "normal" position. That should help you going forward. [/size]
Offline SSG T
  • Hooah
Re: Help! 51 CJ3A
« Reply #157 on: April 06, 2015, 08:55:22 PM »
Alright! i will try to start it tomorrow and take a video for you guys. We can then move on to the fuel pump no pumping gas and the clutch haha. keep your fingers crossed!
Re: Help! 51 CJ3A
« Reply #158 on: April 06, 2015, 11:32:58 PM »
Now we're cookin!
Offline SSG T
  • Hooah
Re: Help! 51 CJ3A
« Reply #159 on: April 06, 2015, 11:46:19 PM »
Is this the mark on the timing case? It was on the motor I blew up.
Offline CJPilot
Re: Help! 51 CJ3A
« Reply #160 on: April 07, 2015, 07:59:02 AM »
[size=12]That is the timing mark[/size]
Re: Help! 51 CJ3A
« Reply #161 on: April 07, 2015, 10:49:23 AM »
See how much you're learning?  You'll be an old pro before you know it.
For timing the newer style engines, you have a notch on the pulley and a bulge on the timing cover.
Old style engines have a window on the bell housing and marks on the face of the flywheel.
You'll be the guy helping a 3A newb before you know it. :)
And you have an advantage over many of us.  You're lucky enough to have both style engines to do comparisons.
Offline SSG T
  • Hooah
Re: Help! 51 CJ3A
« Reply #162 on: April 07, 2015, 02:11:52 PM »
So hooked everything back up and this is what happened. But the fully charged battery died after this!?
Offline SSG T
  • Hooah
Re: Help! 51 CJ3A
« Reply #163 on: April 07, 2015, 02:19:13 PM »
Alright so this was probably a big no no but I hooked jumpers to the starter from my Harley.....check it out!!!!!
Update- I ran the jumper cables from the battery to the starter and it fired up again. Has to be something with the battery cables right?!
« Last Edit: April 07, 2015, 02:27:58 PM by Taber12112 »
Re: Help! 51 CJ3A
« Reply #164 on: April 07, 2015, 02:57:39 PM »
Nice work! Congratulations for sure!
Check all your cable connections and be sure they are all clean steel-to-clean steel...and make sure the ground strap is in place at the front motor mount.....and steel to steel as before....
Now for the fuel pump..!
