Author Topic: Help! 51 CJ3A  (Read 109280 times)
Offline SSG T
  • Hooah
Re: Help! 51 CJ3A
« Reply #180 on: April 08, 2015, 07:37:55 PM »
All the pictures and videos are from my cell phone so they are taken in MP4.
Offline SSG T
  • Hooah
Re: Help! 51 CJ3A
« Reply #181 on: April 09, 2015, 12:15:38 AM »
Alright guys I got the next few days off. What should I do step by step for this clutch? It all appears to be connect correct from the pedal to the arm coming out if the transmission. What could I have done when I took out or installed the motor to screw it up?
Re: Help! 51 CJ3A
« Reply #182 on: April 09, 2015, 05:49:56 AM »
What is the clutch doing or not doing that has you concerned?
Offline SSG T
  • Hooah
Re: Help! 51 CJ3A
« Reply #183 on: April 09, 2015, 09:18:32 AM »
I push it and there is no resistance at all. Just goes right to the floor.
Re: Help! 51 CJ3A
« Reply #184 on: April 09, 2015, 09:34:46 AM »
Ok let's start with the easy-to-get to outside stuff.
Do you have all of these parts?
The most obvious would be the pedal return spring. It's the one that connects to the pedal arm on one end and to a frame bracket on the other end. If it's missing the pedal would have very little resistance.
« Last Edit: April 09, 2015, 10:33:49 AM by Ryan_M »
Offline dat
Re: Help! 51 CJ3A
« Reply #185 on: April 09, 2015, 10:20:21 AM »
it may seem simple, but is the clutch fork on the pivot and in the throwout bearing housing?
Offline SSG T
  • Hooah
Re: Help! 51 CJ3A
« Reply #186 on: April 09, 2015, 10:27:53 AM »
The return spring is there yes. I believe the clutch fork is good. Nothing is obviously out of place
Re: Help! 51 CJ3A
« Reply #187 on: April 09, 2015, 10:39:10 AM »
Here's a pic of what should be inside the bell housing. This is athawk's pic that he posted when helping me with a similar problem.
Offline SSG T
  • Hooah
Re: Help! 51 CJ3A
« Reply #188 on: April 09, 2015, 11:14:36 AM »
Damn, I'm gonna have to drop the transmission aren't I? Everything apears to look OK.
« Last Edit: April 09, 2015, 11:17:26 AM by Taber12112 »
Re: Help! 51 CJ3A
« Reply #189 on: April 09, 2015, 11:24:23 AM »
Will it shift in and out of gear? Are you sure the clutch cross shaft is facing the right direction? It's easy to get it backwards. Let's kick some more ideas around before you go pulling the transmission.
Offline SSG T
  • Hooah
Re: Help! 51 CJ3A
« Reply #190 on: April 09, 2015, 11:28:57 AM »
Thinking back now. When I pulled the motor I had to pull it pretty hard to separate it from the tranny. Could I have screwed something up doing that?
Re: Help! 51 CJ3A
« Reply #191 on: April 09, 2015, 11:35:59 AM »
Possible but unlikely. Way too vague of a question.
Stay focused grasshopper! Answer this and we can move on....
Offline SSG T
  • Hooah
Re: Help! 51 CJ3A
« Reply #192 on: April 09, 2015, 11:45:04 AM »
Yes it shifts in and out fine. I didn't touch the clutch at all so I'm assuming its facing the right direction
Offline dat
Re: Help! 51 CJ3A
« Reply #193 on: April 09, 2015, 12:27:20 PM »
you can see some through the inspection cover on the bell housing
Re: Help! 51 CJ3A
« Reply #194 on: April 09, 2015, 01:58:12 PM »
Ryan was talking about the tube that fits between the frame and the transfer case, the rod from the pedal goes on one end, and the cable to the clutch fork on the other...
Is it in place?..I don't have a good picture...
