Author Topic: '52 M38  (Read 182255 times)
Offline Jeff_M
Re: '52 M38
« Reply #30 on: October 30, 2013, 11:03:42 PM »
Good job getting the old girl driveable.  I really like the top.
Re: '52 M38
« Reply #31 on: October 31, 2013, 05:53:31 AM »
I have seen a tight steer.� How do you like them?
I put one on my 3A to try and remove a small amount of play on a completely rebuilt steering system - it barely made a difference. I took it off and installed it on a friend's super sloppy 2A. It reduced play from roughly 1/3 turn of the wheel to just about 1/4. A remarkable difference but no substitute for properly repairing the steering components.
Offline zooke581
Re: '52 M38
« Reply #32 on: October 31, 2013, 11:49:02 AM »
Thanks.  Nice to know.  Am rebuilding the steering pm mine and wondered of I needed to get one.
Re: '52 M38
« Reply #33 on: October 31, 2013, 12:41:33 PM »
Thanks.� Nice to know.� Am rebuilding the steering pm mine and wondered of I needed to get one.
In most situations I think I'd rather spend the 80 bucks on actual steering components. Other people rave about them so it's likely that I am out numbered with that opinion.
Re: '52 M38
« Reply #34 on: October 31, 2013, 01:25:58 PM »
Regarding the TightSteer...I will quietly agree with Ryan.
With my steering components being new and fresh, I feel very little difference with the TightSteer installed.
That said, as the components wear I anticipate the TightSteer will keep things more crisp, so I left it on.
Re: '52 M38
« Reply #35 on: October 31, 2013, 01:37:24 PM »
Tim -
Your assessment is better stated than mine. My 3A components are too new for TightSteer to make a difference and the 2A I installed one on was way too far gone.
TightSteer is probably well suited to buy a few thousand more miles between complete steering overhauls on rigs with limited amounts of wear. Thanks for translating the true intent of my drivel once again....
Re: '52 M38
« Reply #36 on: October 31, 2013, 04:09:20 PM »
You don�t drivel !!� Your posts are some of the most enjoyable and interesting to read.� I was simply reiterating your original experience. :)
Offline RedWilly
  • Flat Fender
Re: '52 M38
« Reply #37 on: October 31, 2013, 04:13:00 PM »
From a mechanical standpoint, the TightSteer eliminates the need to manual adjust the steering gear. It is not meant to remove play due to worn steering linkage components.
Glen
49 CJ3A
Re: '52 M38
« Reply #38 on: November 09, 2013, 07:28:02 PM »
While a lot of people tend to militarize their civilian jeeps, it seems I am headed in the other direction. So much of the original hardware is missing from this M38 - and while it's a shame not to replace it all, this thing is such a beater that I can't justify throwing the big bucks for original gear when it is possible the frame could break in half at any minute.
The Solex carb has been discarded as it - even with a new fuel regulator - would do nothing but dump tremendous amounts of fuel into the intake manifold. Sooty plugs, horrible burning fuel smell, off it came. I ordered a rebuilt Carter 636 from scoutpilot. It hasn't even arrived yet but in seeing it in the test video he sent me I decided it looks too pretty for the M38 and will go on my 3A instead.
Today, I transplanted the existing Carter from my 3A to the M38. I've done remarkably well not scavenging parts from the 3A, tempting as it is, but I have recently decided if I need a nice new part it should go to the 3A and the hand-me-downs will go to the M38. Now, with the purchase of one part it's like I upgrade 2(!) jeeps. That's like half-price parts, right???
I have also decided it's helpful having two jeeps with the same parts so I can swap them out to help troubleshoot specific problems before blindly buying new parts. I have determined the M38's distributor is in fact junk and I stole the one from my 3A. The 3A, in turn, will get a nice new one.
Fuel tank has been cleaned, repaired, and treated with some sort of magical liner. All new fuel lines installed.
Crusty air cleaner as purchased from Tom here on the 3A page has been installed and is working great. I didn't even bother to paint it as it looks better "as-is".
Rotted muffler was cut off and replaced. It is currently mounted with wire coat hangers but I will improve that arrangement, maybe.
New plugs, wires, dist cap, condenser, and it really runs good now. Temp gauge is working and reads right were it should. I changed the oil again with less than an hour of run time and it was as black as oil gets - pretty gross. I'm hoping the upgrade in carburetors and just flushing the oil a couple times will clean up the engine a little bit.
Next up will have to be the steering. This rig is scary to drive as any hint of a bump sends it into the throes of a death wobble.
« Last Edit: November 09, 2013, 07:30:33 PM by Ryan_M »
Re: '52 M38
« Reply #39 on: November 09, 2013, 07:47:20 PM »
I think it looks great....huge improvements to two jeeps with minimal investment...that sounds like a perfect plan...
Is the bubble wrap there as protection against flailing tools?
Offline Jeff_M
Re: '52 M38
« Reply #40 on: November 09, 2013, 08:10:21 PM »
Good call, lol.  That new gas tank sure looks better than that crappy one it had originally.
I wonder if the new carb will make give the 3A any more power than what it had.
Re: '52 M38
« Reply #41 on: November 09, 2013, 08:40:25 PM »
Good call, lol.� That new gas tank sure looks better than that crappy one it had originally.�
I wonder if the new carb will make give the 3A any more power than what it had.�
Uh, that's a better call than either of you know. I was working WAAAY past my safe frustration threshold the other day while battling to free up that %$^*!!$@# stuck distributor. Utterly pi$$ed, I thrashed a wrench against what I intended to be the already dented up grill. Of course, I missed, and blew out one of the headlights. Real smooth. The broken headlight did nothing to improve my mood. I went outside to rake leaves instead.
Re: '52 M38
« Reply #42 on: November 09, 2013, 10:37:42 PM »
Those things make a nice "pop" when they shatter, don't they?
One flew out of my hand in the driveway to it's complete destruction..took half an hour to clean it up...
Leaves are very therapeutic...
Offline zooke581
Re: '52 M38
« Reply #43 on: November 09, 2013, 11:36:23 PM »
Where is the other leg of your drivers seat?
Re: '52 M38
« Reply #44 on: November 10, 2013, 07:19:49 AM »
The right front M38 seat leg is on the side because of the removable floor. Just can't see it in that photo.
Go up about 6 posts and there is a good photo of the seat from the other side.
« Last Edit: November 10, 2013, 07:21:47 AM by Bob_W »
