Author Topic: Transfer Case very noisy in low range....  (Read 5343 times)
« on: October 07, 2020, 07:07:56 PM »
It's an early stock CJ-5, 6 volt, F-head, T-90 and the D-18 with an inch and 1/4 intermediate shaft, and an overdrive. Just like a 3B but with a different body...
It's surprisingly quiet in all gears, both 2WD and 4WD. Shifts smooth with no grinding. Never been rebuilt.  Shows about 47K miles on the odometer, which still works.
But put it in low range, 4WD, hubs free, and it starts to get noisy, But no noise that may be a broken tooth. I know the low range gears are straight-cut so some noise is expected.
As you might expect the noise rises in intensity on acceleration and decreases when off the gas, doesn't really change otherwise, doesn't go away when coasting even. Of course we are talking maybe 10 mph in third, low range. By then it's quite a howl. You can almost feel it. It's been like this for a long time.
I've looked at the line drawings of the D-18 and can't figure just what is coming under load for this noise to appear only in Low Range, and quiet in 2WD and 4WD High Range.
 I used to drive this jeep around the ranch when I was a kid, mostly in low range because I liked the gear noise!
Now I'm not so fond of it.
I'm  planning to take the bottom cover off and have a look, and if need be I'll rebuild it when I replace the clutch this winter.
Maybe just worn square cut gears? What else to look for?
Maybe the intermediate shaft? But it's quiet otherwise, quieter than the 3A which has been rebuilt.
Thanks!
« Last Edit: October 07, 2020, 08:23:46 PM by 1955CJ-5 »
Re: Transfer Case very noisy in low range....
« Reply #1 on: October 10, 2020, 06:47:39 PM »
I put the rear axle on jack stands, and went through the gears in 4WD ( hubs free!) both high range and low, and no appreciable noise.  I then left it idling in gear and used a mechanic's stethoscope and checked the transfer case and transmission, once again just a consistent mechanical whirring noise, no clicking or growling bearings as far as I could tell. Even put the stethoscope on the intermediate shaft end and no unusual noises there either.
Of course nothing was under load.
So when I get a pump so I can refill the transfer case, I may drain it and take the cover off and see if anything falls out.
Or I'll just leave it alone.
Maybe this is just as normal as can be.....never got to drive the 3a before everything was rebuilt, maybe it would have been the same....
« Reply #2 on: October 11, 2020, 02:02:12 PM »
Randy,
I've not heard a lot of different gearboxes.  I can't even remember what mine sounds like at speed (it's been a while).  That being said, I wonder how much difference there'd really be between the gears in a 3A and an early 5.  I could talk myself into thinking there shouldn't be too much difference (noise-wise).  I did think that during your rear axle off the ground test that a load could be added by feathering the brakes to add drag while spinning.  Don't know if you tried that or not.
Looking inside may be the best thing (after looking at the lube - as you suggested).  I owe my transfer case a look too as I've got to solve a mystery as well.
You may consider posting a video of the noise (if you aren't already beyond that point) and some images of what you see inside.  After using the stethoscope, have you felt the shifters while driving to see if one or the other has more vibration?  I'd be curious, while driving under load causing the noise, if you put some pressure on the shifters (one at a time) both forward and backward - keeping it in gear - to see if the "feel" changes any.
There are guys that can rebuild these things in their sleep.  Sadly, I'm not one of those....
« Last Edit: October 11, 2020, 02:04:34 PM by Rus Curtis »
« Reply #3 on: October 11, 2020, 10:36:41 PM »
Rus,
A video might be interesting. I have an old GoPro that ought to do the trick.
I have the skid plate off and I'm ready to take the cover off, but maybe I'll back track a little and get some video/sound.
I did try the e-brake while it was on the jack stands, the e brake made no difference, didn't think to use the pedal, it would be more effective I'm sure!
I'll also wiggle the sticks and see what I feel or hear.
« Reply #4 on: October 12, 2020, 12:08:22 AM »
Yes, the wheel brakes.  I should have specified.  Hope this shows something.
Offline OnlyOneDR
« Reply #5 on: October 12, 2020, 08:24:17 AM »
If you leave it in 2wd, lock the hubs, and drive it does it make any noise?  Just wondering if the front driveline has anything to do with it.  You are sure that the t-case has enough fluid in it?  It could just be that the intermediate shaft/bearings are worn and since the load is a lot higher on those gears when in low range that it makes more noise.  Might be overdue for a rebuild with a replacement shaft and bearings.
1950 CJ-3A #37751 In Pieces
« Reply #6 on: October 12, 2020, 04:55:01 PM »
I did check the fluids, everything is full.
I did not drive it in 2WD with the hubs locked, but I did drive it in 4WD with the hubs free....I'll try it in 2WD....
I made a short video but it did not capture the noise very well. I'll try again, I don't have a remote microphone and I'm holding the camera and trying to drive safely!
Might just order an intermediate shaft kit and replace it while still in the jeep......I've got to do a clutch pretty soon too.
 I know, just pull it, rebuild it and do the clutch...nothing to it :)
« Reply #7 on: October 12, 2020, 09:37:37 PM »
Here is the video link.
https://youtu.be/cn7QNQf9_NA
I think the noise is apparent.....first 20 seconds or so are of relatively quiet high range, and the remainder is in low, it's really loud when I coast with the clutch depressed.
« Reply #8 on: October 12, 2020, 09:48:03 PM »
I heard it.  A whine almost.  I didn't know you also had an overdrive.  Was it my imagination or when you shifted to low, the two knobs touched?  I don't have an overdrive so I'm not that familiar with them.  Have you shifted the OD to the other position to see if the noise is still present?
Also, is the noise always there during your drives or only when you coast and depress the clutch?
« Reply #9 on: October 12, 2020, 10:09:24 PM »
With the overdrive in there the knobs and levers get pretty crowded. I've bent the OD lever for clearance but it's not perfect.
The noise is present only in low range, and coasting or under power does not matter, you can just hear it better while coasting. It's very consistent and it gets louder the faster you go, all in low range, OD direct.
The first couple of video's I tried it was like "Where is the noise?"
My transmission is surprisingly quiet, quieter than the rebuilt 3a, maybe it's just the contrast between high and low that bugs me.
I may order a intermediate shaft kit.
Anyone tried the Novak, with the "O" rings? Seems to me I tried the "O" ring version on the 3a and the "O" rings kept getting shaved down as you pushed the shaft through. Occasionally they would peel right off the shaft and get involved it the roller bearings....I had the intermediate gear out 3 or 4 times chasing a high pitched whine.
Offline OnlyOneDR
« Reply #10 on: October 13, 2020, 08:30:49 AM »
After listening to the video that actually doesn't sound bad to me.  I will need to defer to the experts on here.  My Nissan with 4:1 transfer case gears whines like that whenever I get going maybe 8-10mph and just gets worse as it goes faster.
« Reply #11 on: November 05, 2020, 10:13:17 PM »
Well, it might be my imagination...but it is definitely louder than the 3A in similar configuration.....
But, I took the bottom cover off anyway.
Oil was a little murky looking, in fact I was a little surprised at how murky it was........I changed it a couple years ago, probably a couple times to flush it out a little....probably no more than 300 miles ago...but before that it had probably been 15 (or 25?)years since it was changed...it had been stored most of the time.
The gears look good. I can turn the intermediate gear and it feels smooth, no clicking or catching or roughness noted. There is a slight perceptible fore and aft movement on the shaft....just detectable...I maybe can measure it tomorrow.
Pictures attached....small rust spots on a couple teeth...no metal bits in the cover...
What to look for?
I bought a Crown intermediate shaft kit, but don't want to install it "just because I got it".....I did not want a Novak type with the two "O" rings, I had one for the 3A and never could get it installed without catching and cutting the "O" rings...still have it in a bag...souvenir of sorts....
I'm thinking that just some fresh oil may go a long way to quieting my transfer case....the transmission will get an oil change too.....and maybe the diff's while I'm at it.....
« Last Edit: November 05, 2020, 11:23:37 PM by 1955CJ-5 »
« Reply #12 on: November 06, 2020, 01:38:24 PM »
The intermediate gear end play...the gap between the gear and the rear thrust washer is .013......is that excessive?
Also a couple of teeth have some very light pitting due to rust....I'll try to get a good picture....
Otherwise all seems tight and smooth....
Thoughts??
« Last Edit: November 06, 2020, 01:43:33 PM by 1955CJ-5 »
« Reply #13 on: November 06, 2020, 04:56:03 PM »
Jumped way ahead of me with this.   I'm needing to pull mine to solve a problem and I'd have to read through the manual to find the thrust washer numbers (yeah, I don't have that memorized..).  I see the pitting but don't know if that's a problem or not (I'd like to think that movement in oil would keep it from getting any worse).  Others here will know more.
« Reply #14 on: November 06, 2020, 08:04:21 PM »
 At the very least I'm pretty sure that a catastrophic failure is not waiting just around the next bend.....
Everything was snug and smooth with no broken teeth or metal bits.
I changed the transmission oil along with the diffs, and of course the transfer case got fresh oil.
I'll drive it tomorrow.
Still gotta think about replacing the clutch...I believe I'll pull the engine for that little project..:)
