Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Willys is a big family.
Home
Help
Search
Downloads
Gallery
Login
Register
"Original"-- Technical Questions, Answers, Observations
Kingpin Bearing Help
« previous
next »
Reply
Print
Pages: [
1
2
Go Down
Author
Topic: Kingpin Bearing Help (Read 9504 times)
LKap
Project Jeep (Newbie)
Jeep Fanatic
on:
April 26, 2017, 05:21:37 PM »
I am not sure what I did wrong! I just tried to set the preload with my new kingpin bearings. Everything seamed to go together just fine and after I bolted and torqued the caps down the preload seemed to be good at about 14 lbs. I unbolted everything so I could put the seals on and when I took a look at the bearings they were damaged. It looks like I didnt have them set perfectly before I tightened everything up. Has anyone ever had this happen before?? Bearings were brand new from Walcks. Regardless it looks like I'm ordering new bearings
Logged
specialty
Willys Guru
1952 CJ3A
Re: Kingpin Bearing Help
Reply #1 on:
April 27, 2017, 11:49:00 AM »
It looks like they were not seated right. Been awhile since I have been in there so one of these guys will know for sure. Sometimes it takes a little time for a reply so hang in there. I think I got my bearings, I think they were national bearings, at Advance auto and used a promo code on them. Might save you a few bucks.
Logged
LKap
Jeep Fanatic
Reply #2 on:
April 27, 2017, 12:16:55 PM »
Thanks for the reply. That's what I'm thinking - not seated right. I hope someone can chime in on how to tighten the kingpin caps down the right way so this doesn't happen again!
Logged
specialty
Willys Guru
1952 CJ3A
Reply #3 on:
April 27, 2017, 12:29:45 PM »
If I recall they just slip in by hand. Did you tap or hammer them in?
Logged
1955CJ-5
Flatfender Master
It wasn't always green....
Reply #4 on:
April 27, 2017, 01:08:44 PM »
My only thought is maybe the outer race/cup is not fully seated, and so the bearing is sitting a little too high when you tighten the caps...
This is a picture of one that came out of my CJ-5.....but it had been in there for 50 or 60 years...
Do you have pictures of the knuckle?
Last Edit: April 27, 2017, 01:31:41 PM by 1955CJ-5
Logged
athawk11
SMF Administrator
Flatfender Master
1949 CJ3A
Reply #5 on:
April 27, 2017, 03:09:39 PM »
The type of damage to the new bearing is a bit of a head scratcher.
There are old style knuckles and a newer style knuckle. The old style requires shims on both the top and bottom king pins. The newer style only requires shims on the upper king pin. There is a post here somewhere that shows the differences quite nicely. I can't find it right now.
Can you post a photo of the lower king pin area on your knuckles?
Logged
LKap
Jeep Fanatic
Reply #6 on:
April 27, 2017, 06:08:23 PM »
I'm pretty sure I have the old style. I researched this extensively before I started so I wouldn't screw up
. There were shims on both the top and bottom when I took it apart. I used the same shims as a starting point when I reassembled. Could it be that I don't have enough shims. Attached are pics of the raced - pretty sure they are all the way seated. I will post a pic of the knuckles when I get home.
Logged
LKap
Jeep Fanatic
Reply #7 on:
April 27, 2017, 07:51:22 PM »
Hawk - here are the picks of the bottom of the knuckle
Logged
athawk11
SMF Administrator
Flatfender Master
1949 CJ3A
Reply #8 on:
April 27, 2017, 11:11:58 PM »
You're right. That is the older style. Load it up with extra shims. Tighten each kingpin nut a little at a time until you reach the recommended torque. Test, then remove shims, tighten, test remove etc...until you reach the recommended foot pounds.
Logged
LKap
Jeep Fanatic
Reply #9 on:
April 28, 2017, 06:40:29 AM »
I read over on the 2a page that the kingpins are torqued down to 55-65 foot pounds. Seems a bit high? Is this correct?
Logged
1955CJ-5
Flatfender Master
Reply #10 on:
April 28, 2017, 10:52:49 AM »
That does seem high....the head bolts are only torqued to 60-70 ft lbs..
They are 5/16 aren't they?
There is a table here for standard bolt torque values...lots of others on the net too...
http://www.engineersedge.com/torque_table_sae_ftlbs.htm
Logged
LKap
Jeep Fanatic
Reply #11 on:
April 28, 2017, 09:30:30 PM »
I was referencing this page - seems legit
http://www.cj-2a.com/techtips/specs/torques.html
Logged
1955CJ-5
Flatfender Master
Reply #12 on:
April 29, 2017, 12:00:56 AM »
Well, you can try it.
Some of the early jeeps had a one piece steering arm/king pin cap, which is what they might be referring to....
Logged
Oilleaker1
Willys Guru
Automotive Archeology/ Jeep Disease, Green Diseas
Reply #13 on:
April 29, 2017, 08:08:11 AM »
You hit it with the cap bolts. There are two that are longer than the others. The long ones hold the guard on top. Easy mistake to make. Oilly
Logged
LKap
Jeep Fanatic
Reply #14 on:
April 29, 2017, 10:30:35 PM »
How would the bolts hit the bearing? I checked and there are a couple that are a little longer. Do I need to test the preload with the guard?
Logged
Reply
Print
Pages: [
1
2
Go Up
« previous
next »
