Author Topic: Kingpin Bearing Help  (Read 9493 times)
Re: Kingpin Bearing Help
« Reply #15 on: April 30, 2017, 09:38:28 AM »
I didn't test preload with the guards.�
I have seen drawings showing bolts and drawings showing studs with nutts. I can't say which is stock on a 3A.� Both of my 49 3As have studs in all locations...top and bottom.� My 2A has all studs on the bottom.� The top has bolts toward to wheel and studs toward the axle.
With Studs, I've never had bearing damage when setting preloads.
« Last Edit: October 05, 2017, 01:16:31 PM by athawk11 »
Offline LKap
  • Jeep Fanatic
« Reply #16 on: April 30, 2017, 08:06:08 PM »
Hawk -  I agree studs or bolts shouldn't make a difference. I have been mulling this over in my head to try and figure out where I messed up.  The most plausible thing I can come up with is that I must have over-tightened one side of the cap forcing the bearing to sit up on the opposite side.  Then when I tightened the other side of the cap down I must have pinched the edge of the bearing.  Sound feasible??  I guess you have to tighten the cap bolts/studs just like you would on the engine head.   I'm gonna try to stop at NAPA tomorrow after work to see if I can get a bearing locally before I reorder from Walks - anyone know the part number?
« Reply #17 on: April 30, 2017, 09:38:00 PM »
I'd think about what John said. Check the length of the bolts before you ruin another set of bearings.
« Reply #18 on: May 01, 2017, 06:10:37 PM »
How would the bolts hit the bearing? I checked and there are a couple that are a little longer.� Do I need to test the preload with the guard????
Just measure the depth of the hole, length of the bolt/stud. If you look up inside, the studs/bolts should not protrude deeper than the knuckle threaded holes.  ;)
Offline specialty
  • 1952 CJ3A
« Reply #19 on: May 01, 2017, 07:36:17 PM »
I really can't see how the bolts or studs could damage the bearings. Wouldn't the bearings have to be out of their place to be hit by the bolt? If that's the case it would be difficult to even get the bolt in. But it has been awhile since I did mine so maybe I am forgetting something.
« Reply #20 on: May 10, 2017, 07:15:42 PM »
I just replaced the front axle shafts and had both knuckles apart. There is no way the bolts can interface with the bearing. The bearing is on a stub shafr on the cap that bolts to the knuckle.
When you push the cap and bearing into the knuckle it should self align because the cap slides into the knuckle housing. As I remember the bolt holes don't go all the way through the knuckle housing.
To be honest I can't imagine how you damaged your bearings.
Offline LKap
  • Jeep Fanatic
« Reply #21 on: May 10, 2017, 09:57:28 PM »
I finally figured it out.  Oilleaker (John?) is totally correct.  Some of us do not have studs, but bolts that attach the kingpin caps.  There are 4 bolts that are a bit longer for attaching the brake guards.  I did not pay attention when setting the preload without the brake guards and must have used the longer bolts.  Carlsjeep- yes the thread holes do go all the way through the knuckles and if you use the longer bolts they will hit the edge of the bearing and cause the damage I experienced. (Reference the pic below!).
Good news - we all learned a valuable lesson.  More good news - I just set the preload with the CORRECT bolts and everything went smoothly.  Bad news - I wasted $80 in trashed bearings  :D
Offline specialty
  • 1952 CJ3A
« Reply #22 on: May 11, 2017, 07:55:46 AM »
Who would have ever thought that? I also have the bolts and do not remember if I did that right or not but everything worked smooth so I must have caught. Nice to know though for future reference. Good job John on figuring it out. Now to can move on to your next problem!!!!
Offline Uncle_Vin
« Reply #23 on: May 11, 2017, 11:22:03 AM »
