Mine is converted to 12 volt, I like it as I can use some of the modern accessories easier, ie winches and lights. I used a coil with an internal resistor, this drops the voltage to 8 volts. Make sure you change your head lights as well, and yes it does make the starter really whirr! I've had this conversion for about 3 years now and have not had a problem with the starter burning out.
