So I worked on things this weekend and found a few things out.
1. I took apart and cleaned my carb and the accelerator pump seems to be working now. Things were pretty gummed up and the linkages and springs were sticking.
2........I took my distributer apart and checked my advance and everything seemed to be working as it should. However, when I put everything back together and installed the distributer back on the jeep.........I am getting no fire to my plugs. The "gasket" between the breaker plate and the distributer housing was pretty dry rotted. There was also a felt bushing around the screw that comes out of the distributer and connects to the coil wire that was pretty rotted. Since I didn't have anything on hand, I reused them. Now, I'm beginning to wonder if that is my problem. Can I use cork to reproduce these gaskets or should I try to hunt down replacement?
When I touch a test light to the coil wire on the distributer (with the ignition on) I get nothing. Moving back to the coil, I get current on the key side of the coil but not on the distributer side....until I unhook the distributer wire. This leads me to believe the distributer has a short in it somewhere........right? Where else can I look for a short?
Randy, thanks for the link! They look like they really go through the distributer and bring it up to snuff. If I go that route, I am really tempted to update to 12 volt and electronic ignition..... I would like to stay original, but my ignorance of old school is really starting to show....
From what I understand, 12 volt is a little bit more forgiving of problems and that is what the vast majority of my experience is in. I know there is nothing "wrong" with a 6 volt system, but there might be more "right" with a 12 volt.
Thanks for the help guys..
