Well, I checked out several things last night and now I have MORE things to check out this weekend.
1. First off, I did get the distributer lined up and fitted down into the oil pump. It was not as easy as it was in the past, and I had to REEEEAAALLY work to get it exactly lined up and then worked into the groove. I have no idea why.
2. With the rotor installed, I can not rotate the rotor either direction. So now I think I need to check my mechanical advance.....
3. I also noticed I have some play (in and out) in my dist shaft. I can't recall if there is any side-to-side movement. From what I'm told.....this is bad also. Does anyone know of a good supplier for new bushings or how hard they are to replace?
4. On top of everything else, when I really got to looking inside my cap, I found my button was missing! The spring was there, but no button! Where did it go? How long has it been gone? How did it even come off?!?!? I have no idea.
5. Finally, to add to everything else and cap off the night I found out my accelator pump on my carb is froze up.
This will be the second time in three years I have replaced this pump because it siezes up. Really thinking I may be buying a new carb from Walcks or send my to scoutpilot to professionally rebuilt.....
It was at this point I calmly set my tools down, washed my hands, turned off the lights and headed into the house to play with my girls. Bubble Guppies and SpongeBob suddenly didn't look so bad......
