Author Topic: Useful tools.....  (Read 42114 times)
Re: Useful tools.....
« Reply #30 on: January 14, 2015, 08:48:53 PM »
Good idea on the drag link covers. All of mine are just floating around.
Offline macrisel
« Reply #31 on: January 15, 2015, 12:31:15 PM »
And how did we exist without tie-wraps
Tell me about it!  I have zip ties on my tailgate chains to keep them from rattling on the gravel roads...
« Reply #32 on: January 23, 2015, 09:35:06 AM »
No workbench or Shop fridge should be without a set of these little beauties!! No more chipped teeth opening those Angry Orchards and Coronas. The "motto" inscribed on the lower "Tool" says it all..
« Last Edit: January 23, 2015, 09:37:34 AM by MC51986 »
« Reply #33 on: February 01, 2015, 08:11:26 PM »
I know I have one of those bottle openers somewhere, but I'm still looking...I may have to go to the antique store and pick one up ;D
If you are planning any brake work, like replacing shoes...save yourself some grief and get a pair of these brake spring pliers...
The pointed end goes against the shoe lining, and the hook pulls the spring nicely into position...I think I paid $8 for this pair...worth every penny!
And the electric rattle gun is perfect for zipping long bolts in and out. It won't loosen the really tight ones, or tighten them a whole lot, but it sure saves the wrist and elbows...
I used to use a screw gun but it would try to twist your wrist around backwards once in awhile...
« Reply #34 on: February 02, 2015, 04:39:12 PM »
I see you're in southwest ID, how far are ya from the Twin Falls area?? Rick
« Reply #35 on: February 02, 2015, 07:12:23 PM »
Looks like the brake pedal is in the clutch pedal postion.
« Reply #36 on: February 02, 2015, 07:50:15 PM »
Thanks Bob, I thought someone might notice that!
It's been that way as long as I can remember but someday I'll crawl under there and change them....
« Reply #37 on: February 02, 2015, 07:52:56 PM »
Hi Rick,
I'm in Boise....
I looked at your map location to see if you were close by and it showed you way up in the mountains somewhere East of Redfish Lake...!
Edit: Hey! I just looked at my profile and my map puts me East of Redfish Lake too!!
« Last Edit: February 02, 2015, 08:01:46 PM by 1955CJ-5 »
« Reply #38 on: February 06, 2015, 10:23:19 AM »
Order has been restored.....and the tool at the bottom is a ratcheting end wrench from Sears...it works fine but doesn't get used that often...
« Reply #39 on: February 06, 2015, 12:51:47 PM »
Many of us rebuild our Carter WO carburetors.  I have avoided removing the aluminum rivets/plugs because I don�t have the special tools to pull and reset them.   The tool... T-109-42 or -43
 On my last rebuild, I really wanted to get into these passages to make sure they are spotless, so I got creative.
This is a very small pry bar I found at Home Depot.  I sharpened the back side with my bench grinder.  This works well to pull the old rivets.
After cleaning, I needed to re-seat the new rivets.  I took a scrap 3/8� steel rod, cut it to around 3�, then drilled a dimple in the end with a 3/16� drill bit.  It was trial and error when determining how deep to drill.    See the result below.  This worked well, and looked identical to the originally installed rivets.
Again, a decent option should you not have the actual Carter tool  T 190-42 or -43
« Reply #40 on: February 07, 2015, 08:39:50 PM »
Great stuff here
 [smiley=beer.gif] [smiley=beer.gif] [smiley=beer.gif]
« Reply #41 on: February 25, 2015, 07:21:48 PM »
In trying to fit my windshield frame in place I discovered that with the installation of the new cowl seal the latching brackets were too low. No amount of force with a screwdriver would budge them. Great.
I thought I was going to have to weld a nut onto each screw head so I could use a ratchet, or worse, drill them out.
Instead, I discovered this today - Impact screwdriver. I never even knew they existed until this afternoon but picked one up at Harbor Freight for $7.99
It was still an epic battle but several good whacks with a BFH and all the screws were out. No welding, no drilling.
Another amazing HF purchase. How do you even make the thing for $7.99? Or ship it here from China for $7.99? Let alone both and still turn a profit?
Offline Jeff_M
« Reply #42 on: February 25, 2015, 07:41:44 PM »
An impact driver can be a very handy thing to have, as you've discovered.
« Reply #43 on: February 25, 2015, 08:33:12 PM »
Ahh yes.  A cool tool.
I have a short story.  I was having trouble early on with the removal of several screws.  You all know these screws�the screws that hold the head lamp buckets to the grill.  The two lower screws are always rusty, and nearly impossible to remove.
I mentioned this to my sister.  Now, my sister is one of those folks that thinks she knows everything about everything, but is often proven a fool after opening her trap.
So, when she told me she has a tool that would help, I was quite skeptical.  First off, she has no tools to speak of.  Secondly, because of previously stated facts, I�m thinking she�s been smoking some Colorado dope. [smiley=s8656.gif]
She goes to the trunk of her car, brings out this very tool, shows me how to use it, and low and behold, it worked like a charm.
So, I guess my sister knows a little something, about something, after all.
Don't get me wrong.  I love my sister, but sometimes she makes me want to drive a stake through my skull. :D
« Reply #44 on: February 26, 2015, 03:19:34 PM »
Geez Tim, might be worth sending her home with one of those ol' Carter's that been giving you fits.
