Author Topic: Useful tools.....  (Read 42277 times)
Re: Useful tools.....
« Reply #45 on: February 26, 2015, 06:40:00 PM »
So, I guess my sister knows a little something, about something, after all.
Geez Tim, might be worth sending her home with one of those ol' Carter's that been giving you fits.
 ;D ;D
« Reply #46 on: November 13, 2015, 11:07:26 AM »
I just rebuilt the rear spring pack on the Model A, and I used this between the leaves when I put it back together.
I haven't driven it yet but the graphite makes it slick to the touch...and it'll dry  almost immediately...
So if you ever rebuild your spring packs....
« Reply #47 on: March 19, 2016, 11:18:18 PM »
Now here is another fun tool...I borrowed this one from a neighbor.
http://www.homedepot.com/p/RIDGID-Micro-CA25-Inspection-Camera-40043/203258908
I think I'd buy one that had picture taking capabilities...
The pic is of the inside of my radiator on the model A..though it looks a little like the Titanic....but you can see that several tubes are blocked.....
« Last Edit: March 19, 2016, 11:20:56 PM by 1955CJ-5 »
Offline GeorgeA
« Reply #48 on: November 21, 2016, 10:41:07 PM »
That is a pretty handy tool!! little bit of surgery on the Jeep. Well found and thanks for sharing
Offline Weldon
« Reply #49 on: August 02, 2019, 10:27:30 PM »
Thank you, just what I need
« Reply #50 on: August 03, 2019, 10:04:24 AM »
Thanks Randy, my wife has a similar device she uses in her veterinary practice, don't think she'll let me shove it into the radiator tho..
« Last Edit: August 03, 2019, 10:47:01 AM by 1955CJ-5 »
« Reply #52 on: November 28, 2019, 05:55:44 PM »
Hub puller. Found on e-bay for $25.  This is one of the old OTC tools, not the cheap China knockoffs!
I'll also include the HF scissor lift that the jeep is sitting on, money well spent.
« Last Edit: November 28, 2019, 06:04:46 PM by Chuck W. »
« Reply #53 on: October 07, 2020, 10:11:48 PM »
Wouldn't a lift be nice!
Anyone use or recommend, pro or con, a transmission jack or maybe a transmission cradle that fits your floor jack?
« Reply #54 on: October 08, 2020, 08:37:22 AM »
I purchased this version from Harbor Freight.  I don't use it much, but having it around has been quite helpful.
https://www.harborfreight.com/800-lbs-low-lift-transmission-jack-60234.html?_br_psugg_q=transmission+jack
« Reply #55 on: October 08, 2020, 11:16:08 AM »
On transmission jacks, what I've read on the 2A Forum is fabricated adapters for the T90 so you can bolt it on and have it secure when pulling or installing - since the gear boxes are off-centered and unbalanced.
One member made an adapter and shared the drawings with me.  Heavy on fabrication.  Another guy just used a spare transmission mount and only had to use spacers to attach to the jack:
https://www.thecj2apage.com/forums/transmission-jack-adapter_topic47617.html?KW=transmission+adapter+jack
Imbedded in the thread is a link to buy just the plate so you can have the adapter for your jack.
I think if I ever need to have a jack I'll use the transmission plate.  Just seems simpler.
FWIW, all state you need to have the jeep up on jacks to give clearance for the jack/drivetrain to clear under the frame rail.
« Reply #56 on: October 08, 2020, 08:40:53 PM »
Thanks for the suggestions.
Wish I had the space to store a dedicated tranny jack.
The plate idea is good.
My jack has a rubber surfaced pad that is held on with bolts. I could probably remove the rubber, add a wooden base and then add supports as needed.
I would think the tranny/tc will be a little unstable perched on top of a jack.
Offline OnlyOneDR
« Reply #57 on: October 09, 2020, 09:24:04 AM »
I have the transmission jack adapter for my 2-1/4 ton HF jack.  I have pulled and re-installed complete transfercase/transmission combos out of my Nissan (looks like the Saturn V rocket as it is massively long).  Never had an issue with it wanting to tip over while it was properly secured to the jack.
1950 CJ-3A #37751 In Pieces
« Reply #58 on: November 24, 2020, 05:43:42 PM »
This vacuum bleeder sure made life easy...
I just finished replacing all the steel brake lines on the CJ-5 and of course needed to bleed the brakes.
This thing made it a snap.......and it makes my wife happy that she no longer needs to push the brake pedal repeatedly...:)
I used 40-50 lbs of air pressure, and first sealed the threads on the wheel cylinder bleeders with a little Permatex thread sealant, as the vacuum can pull air through the threads.
Just one glitch easily remedied.. The bleeder comes with an I/M style air fitting, and it is locktighted into the bleeder....so I got a coupler and put a T style fitting in it and now have an adapter for my system.
« Reply #59 on: November 25, 2020, 09:02:27 AM »
Hi Randy,
I recently purchased a similar version (I think it's 4-Uncles) to flush my daily driver.  I did add Teflon tape to the bleeders, but I was still sucking in air.  I didn't reduce my compressor pressure. (set at 150-160lbs)
I'll cut the pressure and give this thing another try.
