Author Topic: Side Doors from Factory?  (Read 2929 times)
Offline JeepFever
« on: March 11, 2016, 01:35:24 PM »
I am removing this hardware for paint.� �I most likely will NOT be adding any doors in foreseeable future,� �so wondering if I should weld up the holes.� � (there are a couple sets.� :) )
I would leave the holes,� if there from factory.
« Last Edit: March 11, 2016, 01:37:38 PM by JeepFever »
Re: Side Doors from Factory?
« Reply #1 on: March 12, 2016, 07:43:09 AM »
The ones for the hinge are factory (on the right). The two circled in blue look the the factory ones for the door track.
« Last Edit: March 12, 2016, 07:44:18 AM by garage_gnome »
« Reply #2 on: March 12, 2016, 09:05:51 AM »
Your door hinge, in its current, appears to have been moved.  I believe mine matches G-nomes position...and the circled holes in your photo.
« Reply #3 on: March 12, 2016, 09:55:28 AM »
Yeah, I was looking at the body seam in comparison to the top hole. I agree, it was moved up for some reason.
Offline JeepFever
« Reply #4 on: March 12, 2016, 09:04:37 PM »
Thanks guys . .� I will not weld shut the original holes.  (the upper blue circle,  and the lower arrow)
« Last Edit: March 12, 2016, 11:17:46 PM by JeepFever »
