Author Topic: Picked my new jeep up today  (Read 16149 times)
Offline ranchhopper
Re: Picked my new jeep up today
« Reply #30 on: March 09, 2013, 05:01:46 PM »
Got the front clip off the jeep today I found the original color I thought it was blue.
« Reply #31 on: March 09, 2013, 05:52:59 PM »
That's Cerulean blue, a Surrey color. Ad your engine number could easily have been in a Surrey OR a 3A.
Offline ranchhopper
« Reply #32 on: March 09, 2013, 06:04:40 PM »
Got this picture of the longer frame horns they are much longer than my 3A parts jeep they have not been added to you can see where they end under the 3/4 inch steel blocks.
« Last Edit: March 09, 2013, 09:31:13 PM by ranchhopper »
« Reply #33 on: March 09, 2013, 08:47:19 PM »
What is the engine serial number?
Offline ranchhopper
« Reply #34 on: March 09, 2013, 08:55:29 PM »
3J167733 stamped behind the water pump.
« Reply #35 on: March 09, 2013, 09:07:08 PM »
That would be from about 1960, just after the timing gear oil jet changed from 0.070" to 0.040".
« Reply #36 on: March 09, 2013, 09:11:02 PM »
Everything about your new Jeep screams Surrey except for.... M-38 windshield frame, 4WD, 5 gauge cluster and the radiator.
Offline ranchhopper
« Reply #37 on: March 09, 2013, 09:29:02 PM »
I took a closer look at the dash today it looks like they enlarged the speedometer hole and went with a bigger one I thought the surrey had four lug wheels so the axles must be from a different donor vehicle..
« Last Edit: March 09, 2013, 09:30:20 PM by ranchhopper »
« Reply #38 on: March 09, 2013, 10:15:24 PM »
Surreys were ALL 2WD with a different 3 speed than the T 90.. (t86 I think) The original front axle was a beam type, and the rear was a smaller Dana, and as you said, 4 lug. However, everything from a 4WD jeep would bolt up to the engine and springs with minimal modification. MOST �but not all converted DJ's still are on the original DJ chassis, which has a rear gas tank. We have seen ONE 4WD factory jeep with Surrey colors and �upholstery....I forget right now but I think it was a CJ3B.....
I've got a 60 DJ with a tailgate here at the house, with 4WD and a V6 and T-90 from a Cj5 in it. It looks like it was built that way. Too bad it was left outside in Ohio too long as the engine is seized up.
The nice thing about your tub is the lack of tailgate makes it a lot stronger ...but you have a toolbox and can use stock 3A seating, which is a lot easier to find than the dispatcher seats...and again, it is stronger.
To me your frame horns look correct for DJ OR 3A.. The black steel bumper covers the first two inches of frame when you install it, so it makes the frame look a bit different when the bumper is off.
You have the makings of a real nice jeep there.
« Last Edit: March 09, 2013, 10:16:09 PM by F_Bill »
Offline ranchhopper
« Reply #39 on: March 09, 2013, 11:10:31 PM »
Its pretty nice no doubt the front clip unbolted perfect the fenders, grille and hood are all rust free we will see what surprises I get when they come back from the media blaster.
« Reply #40 on: March 10, 2013, 07:28:14 AM »
I forgot about that possibility, perhaps it is factory 4WD. The date codes on the axles, transmission and transfer case will pretty much tell the story.
Offline ranchhopper
« Reply #41 on: March 10, 2013, 07:55:43 AM »
I will be able to easily get all that when the tub is off im going to bring the chassis to work and steam clean it and pressure wash it down and prep it for paint. It doesnt make much sense the steering column should be surrey if the jeep was just retubbed with a surry tub but lack of a serial number in the frame is a bit strange too. I was told by the previous owner for him to get it titled he had to get a state trooper out to verify a vin on the frame but finding none they titled it as a 49 he was told that year they didnt number the frame.
« Reply #42 on: March 10, 2013, 08:04:24 AM »
Willys began to stamp frames with the sequence portion of the VIN somewhere around 1954. Here is a photo from The CJ-3B Page showing the location....
Offline ranchhopper
« Reply #43 on: March 10, 2013, 08:08:43 AM »
OK I will look again it should be right over the spring hangar maybe I didnt look far enough back if there is a number there its going to give me some titling headaches unless I dont say anything about it.
« Reply #44 on: March 10, 2013, 08:13:39 AM »
I wouldn't worry about changing the title for some number stamped on the frame.
