Author Topic: '52 M38  (Read 182267 times)
Offline Ryan_289
Re: '52 M38
« Reply #15 on: October 02, 2013, 02:16:04 PM »
Pretty neat to find a Jeep that's been sitting in a field for God knows how long and get it running just two days later.� Nice job!
I love that feeling.� It really amazes me that there are as many of them that actually do start up after sitting for YEARS.  The cj2a under my screen name was that way.
« Last Edit: October 02, 2013, 02:17:14 PM by Ryan_289 »
Offline zooke581
Re: '52 M38
« Reply #16 on: October 02, 2013, 09:32:39 PM »
By the way, Ryan, where is your oil filter? ;)
Re: '52 M38
« Reply #17 on: October 14, 2013, 08:52:36 PM »
Work continues - Almost every nut is rusted in place and a lot of them strip. As such an epic battle ensues in removing each one - makes for slow going.
I am wire wheeling and rattling canning the underside in a relatively segmented and haphazard fashion. Certainly not the "correct" way to go about it but a short-term exercise in denial about how bad of shape the tub is really in - "ooh, new paint....pretty!"
I would remove the tub and at least wire wheel and paint the frame if I wasn't afraid the tub would completely fall apart in the process.
All new brake components arrived today so I have some shiny new metal to play with for a while.
Gas tank is likely beyond salvation. Note the visible edge of the moisture absorbing sack which is now hard as a brick:
And a couple others:
But most importantly, I have engineered a way to keep 2 Jeeps AND wifey's car all comfortably in the garage. This feat is critical to my own winter survival.� The countless childhood hours of Nintendo Tetris have paid off....
« Last Edit: October 14, 2013, 08:54:09 PM by Ryan_M »
Re: '52 M38
« Reply #18 on: October 14, 2013, 08:57:21 PM »
Well it looks 100% better already. Just a little cleaning and tidying things up goes a long way....
A radiator shop might be able to cook that tank for you, if it's not full of holes....
You guy's are making me want another project and I'm not finished with the one I have!
Re: '52 M38
« Reply #19 on: October 14, 2013, 09:03:49 PM »
The tank is plastered with fiberglass all over the outside, which I'm guessing means it leaks. I just bought another one of FleBay over the weekend for pretty cheap. It too needs work but probably not as much as my current one. I'll wait until it arrives and then decide which one to go with.
Re: '52 M38
« Reply #20 on: October 14, 2013, 09:21:20 PM »
Your garage arrangement looks familiar...
The little black Willys is now out in back.� Whitey, or parts that make up Whitey, are now inside.� One of the wonderful things about the Willys is the small amount of room required to have one...or two...or three. ;)
Glad to see the transformation is on!
Re: '52 M38
« Reply #21 on: October 14, 2013, 09:33:03 PM »
Tim - Is that a Particulate Matter Containment System I see rolled up to the ceiling above the Kubota?
I have a similar system (random tarps and bungee cords vs your plastic sheeting and 2x4's) that I install around the M38 when grinding or painting. The Willys Laboratory....
Re: '52 M38
« Reply #22 on: October 14, 2013, 09:51:30 PM »
That's my make shift paint booth.� It's partially broken down right now.� I had to buy a cover for ODie.� Particulate matter is a concern.� This fear has forced me to do the majority of dirty work out on the driveway.
Offline Jeff_M
Re: '52 M38
« Reply #23 on: October 16, 2013, 10:59:15 PM »
Congratulations on getting all three in the garage.  I must admit, I had my doubts.  This winter, my garage will have two vehicles, a Gold Wing, and a Kubota.  Not a lot of room I can tell you...
Re: '52 M38
« Reply #24 on: October 29, 2013, 06:19:20 PM »
All new brake components are now installed and working - everything from the MC, wheel cylinders, pads, eccentrics, brake lines, and pedal shaft. Pretty much everything except the drums and 3 out of 4 backing plates. The new found ability to stop means I can now DRIVE IT!
I took the first few rips around the neighborhood Sunday and then some more tonight. It's registered and "legal" but I might have a tough time explaining the red gas can on the bumper. I have a used tank undergoing surgery right now that will hopefully be back to me and installed this weekend.
It runs and drives surprisingly well but there are a few things that need immediate attention:
[list bull-blackball]
  • Steering wheel has much less slop than anticipated but I have already survived a death wobble to something is amiss. From the looks of the tie rod ends it's not surprising.
  • Temp gauge is still not working so I'm probably running at 240 degrees and completely oblivious
  • I replaced three shocks but the remaining one was so rotted I broke the top mount and the shock has rusted and fused to the bottom mount. It is currently held in place with a piece of old wire
  • Air cleaner is still non existent. Good thing bug season is over or they'd be funneling right into the ill-tuned Solex. I have a line on one posted for sale here. Hopefully it shows up.
  • I found a small spring on the floor that I'm pretty certain puked out of the distributor. I'll see if I can find its proper place when I attempt to neaten up the timing.
So far I have still resisted the urge to pull the tub. I've been wire-wheeling chunks of rust away by the pound and replacing it with an equal amount of rattle can paint. I'm already a huge fan of the removable panel the M38's have for easy access to the tranny. Not sure why they never made 2A's and 3A's like that. I've already had it off a couple times and all that stuff you dread doing to a 3A for lack of access is now sitting right in plain view, begging you to rip it apart and rebuild it too.�
« Last Edit: October 29, 2013, 08:44:59 PM by Ryan_M »
Re: '52 M38
« Reply #25 on: October 29, 2013, 07:01:29 PM »
Excellent!� I love the personalized plate!
I really like the way it looks.....continue to resist the urge to pull the tub......
« Last Edit: October 29, 2013, 07:02:24 PM by 1955CJ-5 »
Offline BMIC
  • Weekend Mechanic
Re: '52 M38
« Reply #26 on: October 30, 2013, 06:40:25 AM »
Ryan, Looking good... Now that you have had first hand experience with a "Tight Steer" do you think that alone will solve the wobble problem or do you need to replace the king pins?
Re: '52 M38
« Reply #27 on: October 30, 2013, 07:51:09 AM »
I will probably need to replace the kingpins and every other wear item between the steering wheel and the front tires. The TightSteer is good but not a cure-all.
Offline zooke581
Re: '52 M38
« Reply #28 on: October 30, 2013, 10:41:21 PM »
Nice work.  I do know about the brake stuff as I have put on all new brake lines and waiting on Master cylinder.  New brake cylinders on already.  It goes but it must surely stop as well.
Offline zooke581
Re: '52 M38
« Reply #29 on: October 30, 2013, 10:42:25 PM »
I have seen a tight steer.  How do you like them?
