Author Topic: Hawk's CJ3A 13655  (Read 234585 times)
Re: Hawk's 1949 CJ3A
« Reply #420 on: August 29, 2016, 01:26:10 PM »
Some more glamour shots�
 The original period correct license plates ended up matching the wheels.
« Last Edit: October 21, 2017, 10:06:39 AM by athawk11 »
« Reply #421 on: August 29, 2016, 01:53:42 PM »
Awesome, Tim.  Can't wait to see it in real life.  Wally and Clementine (and Rachel) too!
« Reply #422 on: September 01, 2016, 09:17:03 AM »
WOW!
One thing for sure - on the first day of FCT we will have some nice looking Jeeps - What day are you arriving at Mike's?
« Reply #423 on: September 13, 2016, 02:31:51 PM »
Tim would you say that your tunnel transistion piece to the hat channel is butt welded?
I got mine from Classic Enterprises and can't decide if it is supposed to butt together or go over the hat channel...
At the moment it does not sit right trying to overlap it. But I hesitate to trim it back without asking
« Reply #424 on: September 13, 2016, 08:20:07 PM »
Hi Kirk,
I'm not familiar enough with the Walck's set.
I purchased my channels from Midwest Military.� I like them because the hump portion of the channel is part of the long rear channel.� This set is designed to overlap in the center.� They fit together nicely so there was no guessing.� I welded the overlap seam completely.� I purchased these for both 3As.
https://midwestmilitary.com/midwestmilitary/m38p12.html
I know this doesn't help you at this point.� This may be a good question to post on the Tech page.� I'm sure others here have purchased the Walck's set.
By the way, your tub looks great.
« Last Edit: October 21, 2017, 10:14:49 AM by athawk11 »
Offline Roger
  • Camaro guy trying to figure out Jeeps
« Reply #425 on: September 13, 2016, 09:42:18 PM »
Really don't think you want to butt weld that since is it a structural element... that weld would end up cracking with the flexing... really needs to be the overlap like Tim mentioned.  I had the Walcks set of hat channels and the hump but ended up leaving the original in place and just cut and blended the new rails over the top of the existing... welded it up.
Roger
1953 CJ3A (Navy)
1953 356 Porsche
1957 Chevy PU
1969 Chevy RS Camaro
1977 2WD Blazer
« Reply #426 on: September 13, 2016, 10:21:04 PM »
Sorry Kirk,
You got them from Classic Enterprises, not Walck's.�
I may be wrong, but I think the CE and Walck's are similar...where the hump portion is a separate piece.
I agree with Roger.� It may not fit quite as nice as a trim down and butt weld, but I would probably be inclined to leave the overlap.
I tend to get a bit OCD about stuff like this, but quite honestly, once the tub is re-installed on the running chassis, you won't see it...unless you get under there to wipe down the underside.� I'm guilty of this.� ::) ;D
« Last Edit: September 13, 2016, 10:21:36 PM by athawk11 »
Offline trijjicon
« Reply #427 on: October 05, 2016, 06:00:14 PM »
That drive-by in ur earlier video..made me smile & made my day. ty   That rebuild is extraordinary. Very nice job indeed. Congrats.
« Last Edit: October 05, 2016, 06:08:40 PM by trijjicon »
« Reply #428 on: October 05, 2016, 10:12:33 PM »
Thank you Trijjicon.  I appreciate your comments.  In the chassis video, I was was actually going faster in earlier versions, but my wife couldn't seem to keep up with me while filming.  I had to slow down to help her keep the Willys in frame. ;D
Offline trijjicon
« Reply #429 on: October 06, 2016, 06:10:04 PM »
I just got finished looking back thru all the posts on this build. I'm glad u recorded it...cuz most would say....there is no way that is the same jeep. :)  Whatta skill set u have! Absolutely gorgeous. I know she has to b tickled silly. I'm soooo jealous/envious..^..^
« Reply #430 on: October 06, 2016, 06:42:40 PM »
I think the whole build is photoshopped!  ;)
Still...did a great job though...nobody can photoshop like Hawk!
« Reply #431 on: October 07, 2016, 08:55:32 AM »
Yea Tom, I am wondering about this myself now that you mentioned it! Something just doesn't add up - even the spark plug wires are in perfect alignment - hmmmmmm! ;D
But then again, we know Tim and he DOES good work! ;
« Reply #432 on: October 07, 2016, 10:43:09 AM »
You fellas are way too kind.  My real motivations are to keep up with the work that you all put forth. :)
« Reply #433 on: October 07, 2016, 07:49:25 PM »
Truth be known buddy, your rebuilds, in this format will be looked at for a long long time and inspiring many folks to come.  Be proud my friend!
Brett
« Reply #434 on: October 08, 2016, 09:27:36 AM »
Thanks Bretto.
Bretto...a true Willys 'Master Fabricator'. [smiley=s2120.gif]  [smiley=s0817.gif]
