Author Topic: My belated birthday present to myself  (Read 29178 times)
« on: January 10, 2013, 04:31:24 PM »
Tomorrow, my dad and I are flying out to John's (duffer) to get my belated Birthday present. It is a 1918 IHC Titan 10-20. 10HP at the drawbar, 20HP at the belt pulley. We're going to make a side trip and go snowmobiling in Yellowstone.
From the pictures John sent me, it looks to have a lot of original paint. I can see some original red and pin striping on the rear wheels. It still even has all 4 hub caps that always fall off! I sent the pictures to a friend that has two, and he said that this one looks to be used mostly for belt work and very little to no plowing of fields. He also said it is one of the best ones he has seen. I'm real excited to pick it up and meet John!
On the front of the water tank, you can make out the old IHC logo decal. Looks like the picture at the end.
Re: My belated birthday present to myself
« Reply #1 on: January 10, 2013, 05:24:47 PM »
How the heck are ya gonna fit that in your luggage?
Is it large enough to need escorts?
Congrats Nate, looks like it will be a bunch of fun. I can't wait for the videos.
« Reply #2 on: January 10, 2013, 05:35:08 PM »
Haha Bill, we are renting a Uhaul and going to shove it in the back to haul it home.
There will be lots of videos and pictures of it.  :)
Offline johnrb3b
    • Jeeps and stuff
« Reply #3 on: January 11, 2013, 08:10:43 AM »
There will be lots of videos and pictures of it. �:)
Great. Looking forward to seeing them.
I'm an old Iowa farm boy so tractors interest me greatly.
If I could get out of this big city, I'd probably start collecting tractors too. I'm sure my wife would be thrilled.  ;D
Offline gmcjr
« Reply #4 on: January 11, 2013, 02:04:18 PM »
You know, it could come in handy, just in case  the jeep gets stuck. ;D
Gary in N. Texas
51 CJ-3A (old Trusty)
52 Ford 8n (ugly duckling)
46Farmall B (old Rusty)
18 Wrangler Jk
« Reply #5 on: January 12, 2013, 04:42:36 PM »
Oh Man, you have a project on your hands now!!  I used to do tractors, mine were 40s and 50s vintage and I can tell you that those components are a lot lighter than the ones you'll be dealing with!!!  An those wore me out !!!!  Good luck, I'm looking forward to joining you on this journey, from my easy chair of course!!!!
« Reply #6 on: January 16, 2013, 08:45:54 PM »
Phew! Made it back today safe and sound.
Here she is at John's when I first saw it.
It fit in the back of the truck with an inch to spare!
« Reply #7 on: January 17, 2013, 07:22:12 PM »
Some pics of loading.
Some pictures of unloading today.
And I started wrenching on it too. First thing was my dad and I jacked up all 4 wheels and put ATF in the grease cups. The bearings are good and tight which is real rare on these. They used a half *rear end roller bearing.
And then I popped the rear cover off. I was very worried about a bent rod or something horrific in there. Nothing wrong at all! Don't be fooled by the pics, the crank is close to 2" in diameter. The pistons are 6" in diameter or so.
And then I drained the goop out of the transmission. If you worked on a farm fresh jeep, you know what this stuff is. It is found in the transmission, transfer case and differentials.
The original shipping information on the starting flywheel
« Reply #8 on: January 18, 2013, 11:34:55 AM »
That's a very cool tractor. I was thinking it was a lot larger when only the first photos were posted.
« Reply #9 on: January 19, 2013, 08:11:19 AM »
Got the head off the Titan yesterday. One cylinder is perfect. The other had an open valve, so there is rust in there. It is not bad though. Jut minor surface rust. A wire wheeling and a light honing should clean it up nicely. The valve and valve seat are not bad too. When it was put away, someone plugged up the fuel hole in the carb and made sure the throttle and choke were closed. That's probably what saved it.
Offline johnrb3b
    • Jeeps and stuff
« Reply #10 on: January 22, 2013, 11:48:39 AM »
Here are some cool videos of the Titan.
That would be a real hoot to own and run.
Starting
http://www.youtube.com/watch?v=Ahw68RWRaDQ
Running
http://www.youtube.com/watch?v=WuL7KR1lmWw
Starting and driving
http://www.youtube.com/watch?v=ytyJK6yJdFg
Offline 3aJeeper
  • Luvs me a flatfender Jeep!
« Reply #11 on: January 22, 2013, 06:59:07 PM »
What a great project....you are going to have a fantastic time putting that together and getting it running. Looking forward to watching the progress!  :D
1951 CJ3a
F-134 Hurricane engine
« Reply #12 on: January 28, 2013, 08:52:07 PM »
I got the pistons out finally. The rusted up one put up more of a fight. A porto-power here and a hammer there, it came free. I thought you guys would like the engine specs too, 20HP @ 500 RPM, bore: 6.5", stroke: 8", displacement, 531 cubic inches.
These pistons are in perfect shape. The ring grooves are still nice and square unlike the other set. The grooves on the other set are V shaped which is bad because the rings can't seal to the piston. I'll get some new ones though. These rings and pistons tell me this tractor had very little use. They usually look like that junk top ring.
And the rings. The top one came off a spare piston. The lower one is how all the rings looked on the pistons I took out. They still have some life left to them unlike the other.
« Reply #13 on: January 29, 2013, 07:06:13 PM »
Wow �:o , that's 4 times what our Jeeps have �;D
« Reply #14 on: January 30, 2013, 05:52:23 AM »
Oh yeah, everything is big on this bad boy.
