Author Topic: My belated birthday present to myself  (Read 29196 times)
Offline 3aJeeper
  • Luvs me a flatfender Jeep!
Re: My belated birthday present to myself
« Reply #15 on: January 30, 2013, 09:52:46 AM »
At least you're not chasing small parts around the floor! �;D
Hate when that happens.... �:D
That looks like so much fun....really enjoying the posts.
« Last Edit: January 30, 2013, 09:52:58 AM by JBCarney »
1951 CJ3a
F-134 Hurricane engine
« Reply #16 on: January 30, 2013, 10:47:38 AM »
Oh there are plenty of little parts to go with the big stuff, check balls, valve spring retainer clips, specialty bolts, and little mechanical oiler parts.
« Reply #17 on: February 05, 2013, 08:34:06 PM »
Lots of new updates to share on the Titan's progress. I got the new piston rings in. I checked the ring gap in the bores and that was perfect, a tad wider than an 1/8".
New ring versus old.
I had to file the corners off because these rings are pinned on the pistons. You can see the pins here. And this rings are really easy to put on, probably easier than the automotive ones.
And viola! Pistons are bark in there homes. I so can't wait to fire this thing up!
And I also got in the missing carb piece. I got a reproduction cap for it too and made a needle valve for it out of a 3/8" bolt and an old water spigot knob. At least these reproductions are exact, it even comes with the part number and IHC logo cast into it just like the originals!
And then to top it all off, I figured out what all the original writing says on the fenders and shift lever. Got to love the old time warnings. No mention whatsoever of where you shouldn't put hands or feet!  :o
This one says "Wait to shift gears until clutch stops"
"Chains too loose may break sprockets
Shift axle eccentrics to tighten chains
See instruction book"
This is the hardest to read, but it says:
"Operator should enter seat
before shifting clutch lever"
« Reply #18 on: February 10, 2013, 09:59:36 PM »
Now that is just too cool!
We had one of those on the ranch in Nevada, I think it was a 1917, data plate boasted 10 drawbar horsepower. �You could see part of the I-H on one of the fenders..We never did get it to run, one piston was frozen solid..I tried all one summer to get it loose, but no luck. but I had no tools to speak of and had no idea what I was doing....
I sure hope you get it running....
« Last Edit: February 10, 2013, 10:52:23 PM by 1955CJ-5 »
« Reply #19 on: February 11, 2013, 09:13:13 PM »
They didn't make 'em in '17. �;) Their production run was from '18 to mid '22. Then the Fordsons came out and that was the end of low RPM big piston tractors. What ever happened to it?
Yes, they did have an IHC logo on the backs of the fenders.
Oh, I'll get it running. Heck, I've revived much worst and I even built my own engine!  :o  ;D
« Last Edit: February 11, 2013, 09:14:45 PM by garage_gnome »
« Reply #20 on: February 13, 2013, 06:05:52 AM »
I got the head back on it and it has compression. I can't wait to fire this thing up!
A then I also found the original decals on the rear fenders. I has the IHC logo between two globes. Below that it has TITAN and then below it ays 10-20.
same as above, different angle.
« Reply #21 on: February 14, 2013, 10:29:03 AM »
I pulled the water tank off today. It looks like swiss cheese on the bottom. :'( I might be able to fix it unless I can find a good used one.
Look at all the original gray paint under there.  :)
And then while I was oiling it down, I found some more original writing; the oil level for the governor.
Offline Jeff_M
« Reply #22 on: February 18, 2013, 10:24:05 PM »
That thing is awesome.  And, you are a very talented young man.  I'll be watching for more pics!  And of course a video when it is running (I said "when", not "if")!
« Reply #23 on: February 22, 2013, 08:57:54 PM »
That thing is cool Nate!  You always have some sort of project going on, don't you?   ;D
Are parts readily available for that or are they hard to find?  I saw where you got a reproduction part in, do many companies make parts for these tractors?
Keep up the great work.  Like all the rest, I'm looking forward to seeing some video of this bad boy running!!
« Reply #24 on: February 24, 2013, 07:59:59 AM »
Nope, only parts you can find for this are rings, valves, valve springs, some magneto parts, decals and paint. Everything else either has to be made  or find someone with a parts tractor.
« Reply #25 on: March 10, 2013, 09:58:31 PM »
It lives!!! After cranking it over and over... I got it popping yesterday. Got frustrated and came back at it today. After some messing around, it runs just like it was shut off yesterday! The pitted cylinder has good compression too after some carbon build up.
http://www.youtube.com/watch?v=JY4qqxqfVEc
« Reply #26 on: March 11, 2013, 06:29:22 AM »
That is just too cool! Is it ready to go for a ride?
« Reply #27 on: March 11, 2013, 08:55:30 AM »
Not quite yet. I still have to fix the water tank and get the proper lube for the transmission.
« Reply #28 on: March 30, 2013, 10:36:41 PM »
Oh, I'll get it running. Heck, I've revived much worst and I even built my own engine! �:o �;D
Just finally getting back to your thread....hope you weren't holding your breath!
The old tractor was sold abut 15 years ago to someone who lived on the west slope of the Sierras..a tractor buff so I expect he got it running....
Yours is awesome...first one I've heard run...
« Reply #29 on: April 08, 2013, 08:30:57 PM »
Well, at least it went to a good home!
Just one update so far. The water tank is done!
I too the end off that was facing the operator so I wouldn't loose too much patina. I built a new tank from an old in-ground lift oil tank. I made it a real tight fit and slid it inside the original tank. So now the old tank is just a skin and it has a beefy gut. I painted it flat black so it would be hard to notice through the holes.  ;D Tomorrow, I'll put it on, and this puppy will be ready to go!
