Author Topic: NEW E85 in the market???  (Read 1340 times)
« on: April 12, 2026, 10:43:30 AM »
E85 (15% alcohol content) gas has again come to the "fuel market" at the pump.  BUYER BEWARE!!!
When originally marketed, E85 was advertised as "110 octane" and was the "cheapest priced fuel".  It is NOT for everyone.
Now, the article attached seems to indicate E85 as just "88 octane"???  What is deceiving to me is... that in the two attached pics of pumps, one only shows a non-defined "88 OCTANE button" next to the "87 Octane button" (regular) that we have become used to selecting for the most part. (no prices indicated).  TOO easy to make a BAD CHOICE???
Note... Diesel is the "green button".
 see attached pic...
 This next preferred pic shows lots of background contrasts to indicate different choices.  However, now what do you get "if" you chose the " separate E85 button" next to the "88 OCTANE=E85" indicated button???  The article attached tells WHY it is so risky of a "choice" if "not sure what you are choosing and getting"... or what your vehicle can use???
Buyer BEWARE!!!
https://www.msn.com/en-us/autos/other/can-e15-gas-damage-your-engine/ar-AA1VocBy?ocid=msedgntp&pc=U531&cvid=69db9df5654a44869b1f4b8a6a9e6761&ei=19&cvpid=69dba1a1d8b74c9cbbb1a9e6dd681f64
Offline Mark W.
  • Chug A Lug
Re: NEW E85 in the market???
« Reply #1 on: April 16, 2026, 01:45:28 PM »
E85 is 85% alcohol and will only run in cars that are FLEX fuel or specially tuned for it.
E15 is 15% alcohol and for the most part should not be used in autos older then 2001 (though some cars older then 2006 should not use it check your owners manual.
Chug A Lug
1948 CJ2A Tub and Title
1949 CJ3A Windshield
1957 CJ5 Frame and Springs
DIY Aluminum Hard top
Offline BillT
« Reply #2 on: April 17, 2026, 08:55:34 AM »
Thank you for the info.
Love to camp
