Author Topic: 6 volt to 12 volt  (Read 2503 times)
Offline tow hook
6 volt to 12 volt
« on: December 08, 2022, 01:58:44 PM »
hey,
 i have a 1948 cj 2a that i just got. it's missing the generator. but came with a 12 volt battery. so in theory i should be able to swap the 6 volt starter solenoid  to a 12 volt model and add in a 12 volt generator or 12 al.t right ?  seems easy enough ?
 thanks
Re: 6 volt to 12 volt
« Reply #1 on: December 08, 2022, 02:51:31 PM »
There's an article covering this on the 3B Page.  The starter can be left but it will wear faster and eventually need replacing (possible damage to the ring gear too).  12V charging system, a resistor for the coil (or a coil with internal resistor) and bulbs.
Offline tow hook
« Reply #2 on: December 29, 2022, 11:04:01 AM »
thanks, i'll check it out. the only item left was the starter, so replacing the rest won't be an issue.
Offline derekredmond
  • CJ3B.info
    • CJ3B.info
« Reply #3 on: February 20, 2023, 04:34:26 PM »
Yep, the article is at https://CJ3B.info/Tech/SixVolt.html
Derek
Derek Redmond
Kingston, Ontario
https://CJ3B.info
