Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Willys is a big family.
Home
Help
Search
Downloads
Gallery
Login
Register
"Original"-- Technical Questions, Answers, Observations
dwell and distributor shaft bushings
« previous
next »
Reply
Print
Pages: [
1
Go Down
Author
Topic: dwell and distributor shaft bushings (Read 2208 times)
locomotive2111
Still Plays With Jeeps
on:
June 28, 2022, 08:49:10 AM »
Hi everyone, I was having an unusual misfire condition and after much research and study I found the answer. The problem was caused by worn distributor shaft bushings which caused the points dwell to vary greatly . Dwell of course is the time the points are closed which relates both to timing which affects idle and coil saturation or voltage at the plugs. Here is a web site that really explains it better.
www.howacarworks.com/ignition-system/checking-the-dwell-angle
. I know you can avoid this problem with a conversion to electronic ignition but us purists like points. I spoke to a race car builder who explained the need to maintain the distributor to get peak performance. Good luck and keep on Jeepin.
Logged
Mark W.
Willys Fan
Chug A Lug
Re: dwell and distributor shaft bushings
Reply #1 on:
June 30, 2022, 09:24:57 AM »
Or just put new bushings in your distributor
Logged
Chug A Lug
1948 CJ2A Tub and Title
1949 CJ3A Windshield
1957 CJ5 Frame and Springs
DIY Aluminum Hard top
Reply
Print
Pages: [
1
Go Up
« previous
next »
