Author Topic: dwell and distributor shaft bushings  (Read 2210 times)
Offline locomotive2111
« on: June 28, 2022, 08:49:10 AM »
Hi everyone, I was having an unusual misfire condition and after much  research and study  I found the answer. The problem was caused by worn distributor shaft bushings which caused the points dwell to vary greatly . Dwell of course is the time the points are closed which relates both to timing which affects idle  and coil saturation or voltage at the plugs. Here is a web site that really explains it better. www.howacarworks.com/ignition-system/checking-the-dwell-angle. I know you can avoid this problem with a conversion to electronic ignition but us purists like points. I spoke to a race car builder who explained the need to maintain the distributor to get peak performance. Good luck and keep on Jeepin.
Offline Mark W.
  • Chug A Lug
Re: dwell and distributor shaft bushings
« Reply #1 on: June 30, 2022, 09:24:57 AM »
Or just put new bushings in your distributor
Chug A Lug
1948 CJ2A Tub and Title
1949 CJ3A Windshield
1957 CJ5 Frame and Springs
DIY Aluminum Hard top
