Author Topic: Carb/ govenrnor linkage pic request  (Read 1261 times)
Offline cjbilly
« on: January 13, 2021, 08:41:34 AM »
Good morning,
Been working on our '54 CJ3B with an existing governor that was already installed. We replaced the existing carb with a solex.
Since the solex side linkage is slightly different, the crossover bar/linkage from the solex to the govenrnor bellcrank bar has some interference. It hits the bottom spark plug wiring loom at full throttle. Possible fixes- it appears we could raise the loom or rotate 180 towards the firewall.
Just asking if anyone has experienced this small issue and came up with a solution. Pictures are worth a 1000 words.
Thank you!
1984 CJ7
1989 MJ
1946 CJ2A with Supersonic motor (future build)
1948 CJ2A with rear PTO
1955 Sears/David Bradley Trailer
1955 CJ5 with rear PTO
1954 CJ3B with trencher and front blade
Re: Carb/ govenrnor linkage pic request
« Reply #1 on: January 13, 2021, 09:36:04 AM »
With the ongoing documented issues around Solex carbs, you may want to consider having the original carb "rebuilt" instead of "more changes", for a longer run without issues.  Just a thought out loud.  It will be interesting to see what others with more experience have to say.
