Author Topic: Adding separate gauges to speedometer cluster  (Read 4341 times)
Offline Mytwojeeps2020
« on: December 20, 2020, 01:40:54 PM »
The gauges in my '61 CJ5 speedometer cluster are working, including the oil and amp idiot lights.
I'd like to keep this, but would like to add an under dash three-gauge panel for better accuracy (oil pressure, water temp, voltmeter)
Hooking up the voltmeter is no problem, but the oil and water gauges may be.
I'm guessing that the oil and water inserts/plugs might be teed where they connect to the engine, with a line going to each gauge...
Has anyone done this?
Thanks!
The attached pic is the cluster speedometer I have now (in the pic, the fuel & water gauges are gone - I have mine)
« Last Edit: December 20, 2020, 01:43:31 PM by Mytwojeeps2020 »
Current Jeep: 1961 CJ5 “Olaf”
Offline OlDaz
Re: Adding separate gauges to speedometer cluster
« Reply #1 on: December 20, 2020, 06:58:54 PM »
Depends a lot on which engine you are running. Oil isn't usually a problem, just add a suitable "T". Water temp can be problematical though, as a mechanical gauge has a bulb end that needs to go in the head where the original is - if using an after-market electric gauge, it will usually work with a suitable "T" arrangement, but doesn't look very good. Have a look around your cylinder head and see if there's any other ports with a plug that you may be able to remove and use.
« Reply #2 on: December 21, 2020, 05:57:31 PM »
Will do, thanks!
