Author Topic: Bellcrank Rebuild  (Read 5890 times)
Offline Stingray
Bellcrank Rebuild
« on: October 30, 2020, 10:08:55 PM »
Just finished installing a 1 7/8 CJ2A bellcrank rebuild kit. New shaft,bearings, sleeve, and seals. Greased it, tightened it up and it turns smoothly. Only thing is it has about a 1/16 to 1/8 inch vertical play, just so slightly when you lift up on the bellcrank. Is this normal? Thanks
Offline ojgrsoi
  • Learning about the L134
    • The Jeep DJ5
Re: Bellcrank Rebuild
« Reply #1 on: November 21, 2020, 09:07:16 AM »
I am getting ready to do the same thing.  Anyone know the answer?
Mark
1949 CJ-2A
2025 Jeep Gladiator Nighthawk
1969 Dodge D100
*50 VJ,60 CJ5,70 DJ5 Postal Dispatcher,66 FORD M151A1,51M38,73 IH Cub154 LoBoy,70USA DJ5 LHD,67 CJ6,78USN DJ5F LHD,79 DJ5G,*All SOLD
« Reply #2 on: November 22, 2020, 11:32:32 PM »
Well, I went out and checked the early CJ-5. Bellcrank has been replaced along with the shaft/bearings etc.....It is installed so is hooked up to the drag link and tie rods, but I can't move it in any direction.
I think there was an issue with this on the 3A though. I used a combination of the old parts and the new till I got a good fit.
Did your kit have bushings or needle bearings? We went through this back when...I'll look for the thread...
Offline Stingray
« Reply #3 on: December 07, 2020, 09:57:16 PM »
Disassembled the bellcrank and started over. The replacement bearings have needles with spaces between them and the original I removed didnt have the spaces but more needles. Not too happy about most of the reproduction parts out there so I used my original bolt and searched and found the original bearings and sleeve and rebuilt it using the combination of old and new parts like you did. Now all is good. Pays to search out original parts either nos or used.
« Reply #4 on: December 07, 2020, 10:57:52 PM »
Glad it worked out for you.
I remember going round and round with this, eventually using a combination of new and old....
I never throw old parts away, sometimes I can't find them, but that's another story...:)
If you rebuild the steering box keep the old sector arm... if the worm gear contact points are worn you can loosen the points, turn them 90°, weld in place and reuse the old shaft, if the shaft itself not too worn...
Repro parts seem to be about the same marginal level of quality no matter the vehicle type.....some good, some not so good.
Offline ojgrsoi
    • The Jeep DJ5
« Reply #5 on: December 09, 2020, 11:06:07 AM »
I ran into the same thing (aftermarket parts that don't fit) when rebuilding my steering box.  I ended up finding a NOS steering sector shaft which was the same at the original worn one.  IDK what the old sector fits, maybe CJ2A or 3A?  It is the correct diameter but a little short.
If someone would like it you can have it for free.  I just need $5 for shipping.  Here is a photo.  The new one ON THE LEFT is a bit too short for my M38.
« Last Edit: December 10, 2020, 09:10:48 PM by ojgrsoi »
Mark
1949 CJ-2A
1969 Dodge D100
Offline Bruce_W
« Reply #6 on: December 09, 2020, 09:08:15 PM »
 I'm sorry, you have me a bit confused _ which is "new", which is "old"? The one on the left in the picture is obviously newer than the one on the right, so should be the "new" one. Which one do you want to get rid of? If it's the one on the left, I'll take it. Just tell me where to send the $5.
BW
Offline ojgrsoi
    • The Jeep DJ5
« Reply #7 on: December 10, 2020, 09:11:39 PM »
BW
.PM SENT.   :)
Mark
1949 CJ-2A
1969 Dodge D100
Offline Bruce_W
« Reply #8 on: December 10, 2020, 10:12:05 PM »
BW
.PM SENT.   :)
$5 sent. BW
Offline tow hook
« Reply #9 on: December 16, 2020, 02:20:28 PM »
 mine did the same, i hope that tite steer helps, ( it keeps spring loaded tension on that bell crank)  let you know when i get it in the spring
Offline fasilpereira
« Reply #10 on: June 04, 2024, 02:10:05 PM »
I am also rebuilding my bellcrank, removing the bushings and installing a needle bearing kit. What is the correct orientation of the seals? Lip facing inside (same way as pressure oil seals) or lip facing outside?
If I don't get an answer, I am more inclined to install it with lips facing outside to prevent dust from coming and to facilitate the removal of old/dirt grease during the regrease process, but I'd rather install it the right way...
Thank you,
Fabricio
