Author Topic: T98 to d18 shared oil?  (Read 2541 times)
Offline DavidF
« on: August 02, 2020, 11:36:50 AM »
I’m sure I used to know this, but do they share oil? It’s a pain to access the t case fill on my b, just wondering if I can overfill the transmission a smidge.
Thanks, Dave
Re: T98 to d18 shared oil?
« Reply #1 on: August 02, 2020, 01:30:28 PM »
Quote from: DavidF
Thanks, Dave
David,
Do you have a T98 on your 3B?  I know the T90 shares oil on mine, but know nothing about the T98.
Offline DavidF
« Reply #2 on: August 02, 2020, 02:51:45 PM »
Yes, I swapped it in from a cj6 a few years ago. I pretty much never use first gear, but use second as its synchronized. Not sure if I’d bother swapping it now
« Reply #3 on: August 02, 2020, 03:22:32 PM »
Quote from: DavidF
(I'm quoting because your posts aren't visible and in case others want to see without logging out, like I need to, I quote to copy your posts)
David,
This helped.  I don't often reference my late Service Manual, SM-1046, but bought it as it covered CJ-3B also (plus CJ-5/5A and CJ-6/6A and the DJs too).  Sure enough, there was a section on the 4 speed T98.  I didn't see anything in that section, J1, that mentioned lubrication.  Checking the B section however, I found a note at the bottom of the page associated with the directions for lubricating the transmissions on the 4WD vehicles page.
8.  Transmission:
    3 Speed.....
    4 Speed °..... (notice the degree symbol)
At the bottom of the page the explanation:
" ° 4-Speed transmission and transfer case require separate lubrication of each unit."
Both list GL-4 80wt. or 90wt.
Not what you wanted to read, I know.  If someone else knows differently, hopefully they check in.
« Reply #4 on: August 02, 2020, 03:49:32 PM »
The T98-A is sealed between the  transmission and transfer case.
The seal is actually located in the transmission to transfer case adapter plate.
Offline DavidF
« Reply #5 on: August 02, 2020, 04:02:29 PM »
Thanks everyone, i'll check them separately. I appreciate the help.
i need to redo my exhaust anyways, maybe i'll add a drop out section to make it easier
