Author Topic: what size/ group battery do you use ?  (Read 3760 times)
Offline tow hook
« on: July 07, 2020, 02:38:27 PM »
i got a battery hold down kit from kaiser willys  https://www.kaiserwillys.com/steel-battery-hold-down-kit-fits-46-71-cj-2a-3a-3b-5
and can't seem to find a battery that fits well. if it was a 6volt system then i found a few. but i'm coming up short, a 24 f seems to be the battety but it doesn't fit. k/w said to got to tsc. no luck there :(
what are you guy using ?
thanks
Re: what size/ group battery do you use ?
« Reply #1 on: July 07, 2020, 06:03:29 PM »
I only run 12 v systems and my “1 favorite is the group 24F.
Fits my tray and the hold down both.
« Reply #2 on: July 07, 2020, 06:08:14 PM »
When I selected my battery, I used a chart like this:
https://www.jegs.com/Sizecharts/bcigroup.html
To see how the sizes compared.  I wanted a popular, easy to find group - just in case.
I also researched other classic vehicles that had similar hold-downs like ours.  But, on ours the hold down rods are off-set from center.  In the end, I bought a replacement battery hold down and took it to a shop to have it lengthened.
Also, even though the math worked, I still took it with me into the store to test fit over the batteries.  From what I've seen, the hold down looks different for a 12V vehicle.  I wanted the older style.
Offline Mark W.
  • Chug A Lug
« Reply #3 on: July 07, 2020, 09:57:49 PM »
I modified my inner fender to allow a series 31 battery 1000CCA its huge same size we use in our dump trucks at work.
Chug A Lug
1948 CJ2A Tub and Title
1949 CJ3A Windshield
1957 CJ5 Frame and Springs
DIY Aluminum Hard top
Offline tow hook
« Reply #4 on: July 08, 2020, 10:29:45 AM »
 thanks the 24f is too big for my hold down :(
Offline tow hook
« Reply #5 on: July 08, 2020, 10:32:15 AM »
thanks, i got a tractor battery ( with out a handle ) it's an inch to narrow, time to modify the hold down
Offline tow hook
« Reply #6 on: July 08, 2020, 10:33:03 AM »
 thanks, i bet the spins the starter fast !
Offline Mark W.
  • Chug A Lug
« Reply #7 on: July 10, 2020, 11:26:05 PM »
Haven't started the engine yet. But I am running a Toyota 6cyl starter so I am sure it will spin my new 140cuin 7.2-1 engine just fine.
Chug A Lug
Offline tow hook
« Reply #8 on: July 21, 2020, 10:41:09 AM »
thanks, i got the battery hold down shortened and fits tight. the 3b is at the willy doctor to figure out why i don't have oil psi.  battery steems strong, and cranked well.
