Author Topic: Some Posts Not Visible  (Read 25744 times)
0 Members and 31 Guests are viewing this topic.
Re: Some Posts Not Visible
« Reply #15 on: April 18, 2020, 05:02:22 PM »
one's and zero's confuse me.  Good luck Pascal - hopefully you can find something.
Offline derekredmond
  • CJ3B.info
    • CJ3B.info
« Reply #16 on: May 06, 2020, 09:15:39 AM »
There was a guest post in the For Sale forum, titled "One Owner, Original 1963 Willys CJ-3B" which did not appear to have any content, so I moved it to the Recycle section, where it is now the top post.
Maybe others would want to take a look at this post and see if it's an example  of this problem, or whether it is just a blank post.
Derek
Derek Redmond
Kingston, Ontario
https://CJ3B.info
« Reply #17 on: May 06, 2020, 11:18:43 AM »
Derek,
I've searched and can't find "recycle"  - I even used the "search" box and saw several posts stating items moved to "recycle" with links.  I clicked on the link and got a message stating the item is not available or I don't have permission.
Could recycle be a Moderator function only?
Maybe everyone else can see it but me!  lol
Offline Forum Master
  • Don't mess with Mr.Willys!
« Reply #18 on: May 09, 2020, 02:31:36 PM »
Yep, recycle is visible only for admin.
I moved back the post that you mention Derek since i see It. There is content to this post.
Willys is better then Ford! Proove? They don't stample their parts for warranty.
The quality of the forum is made by the quality of the forum's people itself.
  • CJ3B.info
    • CJ3B.info
« Reply #19 on: May 09, 2020, 05:18:59 PM »
OK, thanks.  It's still blank for me.
Rus, sorry to cause confusion!
Derek
Derek Redmond
Kingston, Ontario
https://CJ3B.info
« Reply #20 on: May 09, 2020, 05:33:59 PM »
I think all of this helps.  That add is also blank for me too.
« Reply #21 on: May 09, 2020, 06:01:46 PM »
I can see the content in the CJ-3B for sale post. Sure does look like a nice original CJ-3B!!!
Offline Chris P
« Reply #22 on: May 09, 2020, 06:53:12 PM »
I still can’t see Oldtime’s post. They all look blank. And this it indeed terrible! I am not getting info from an expert!
Chris
1943 Ford G.P.W (located in Argentina)
1944 Willys MB (located in Argentina)
1948 Willys CJ2A (located in Mexico)
1956 Willys CJ3B (located in Mexico)
New: 1957 Willys CJ5 (located in Mexico)
« Reply #23 on: June 07, 2020, 09:03:34 PM »
I too am now having this "blank post" issue, and I never had it before this past week.  It happens in both Chrome and Firefox, though I have no idea if that is relevant.
Admin...is there a fix in site?  Or is the issue on my end?
« Reply #24 on: June 10, 2020, 11:05:37 AM »
Maybe I missed it...what is the consensus on why this is happening and can it be repaired?
« Reply #25 on: June 10, 2020, 12:23:04 PM »
We're all still waiting.  I suspect sometimes, these things fix without doing much.  Other times, it takes a lot of digging to find out if it's just one problem or several different issues that all look alike.
In the mean time, when I encounter these blank posts, I just sit and wait to see if there's another post afterwards that will help me "fill in the blanks" in hopes that I can follow along.  Sometimes I can't.
« Reply #26 on: June 10, 2020, 02:48:12 PM »
I'm just wondering out loud if "when you joined the site" has anything to do with the "experiences".  It seems newbies like myself are not having issues seeing the posts.  Some kind of "membership transfer link" issue maybe?
« Reply #27 on: June 10, 2020, 04:13:48 PM »
Just to add to the mystery...
When I view the new thread about the $2000 project, I can't see the comments while I'm logged in to the site.  If I log out of the site, then view the thread, I can see the comments.
I have no idea how to fix this issue.
« Reply #28 on: June 10, 2020, 07:56:07 PM »
I had wondered if there was a connection between using a PC (me) and others using a mobile device.
Hawk, I'm trying your tweak.  Logging out to see if posts are visible...
« Reply #29 on: June 10, 2020, 08:12:36 PM »
Wow!
I just had to get back on and make another post!  athawk11's mention of logging off worked!  I went through this entire thread clicking on all threads that had blank posts mentioned - including the $2000 project mentioned by hawk (it was all blank to me after the photos).
ALL POSTS WERE VISIBLE WHEN LOGGED OUT AND VIEWING AS A GUEST!!
To me this narrows it down just a bit.  Thank you hawk for that suggestion!
Added:  Might as well mention this too.  Each link that I clicked on to verify the posts were visible (as a guest) I left those tabs open.  Then after logging back in, I went to those tabs and noticed they all showed as "guest" with me not logged in and the posts were still visible.  I then "refreshed" each tab to see if the posts would stay visible but as soon as each tab refreshed, showing me as logged in, those same posts went blank again......
« Last Edit: June 10, 2020, 08:18:06 PM by Rus Curtis »
