Author Topic: Belleview winch install on my "B"  (Read 3682 times)
Offline JeffH
  • Ol skool jeeper
« on: January 11, 2020, 06:32:52 PM »
It's been a long road but I finally got my rebuilt Belleview winch installed on my CJ3B. I originally installed the winch with the bumper in the original location but found the lever to engage the winch was too close to the grill to operate.  So I added spacer blocks to move it forward 1". I beefed up the orig bumper mounting to handle the winch. Still need to buy/install the winch controls and wind the removed cable back onto the winch.
Red '48 CJ2a Chevy 283, SM 420 trans, Brennans disc kit all corners Lockright in D41, Powerloc in D25, 3.15 Terra Low in D18, Belleview winch soon, original Jackman rims! Beachwood Canvas trailrun top
Re: Belleview winch install on my "B"
« Reply #1 on: January 12, 2020, 02:24:14 PM »
Cool Bellview set up !
Offline JeffH
  • Ol skool jeeper
« Reply #2 on: January 13, 2020, 04:49:16 PM »
Here's the just got it home pic! Can't believe it was just a few miles down the road from my home in Gawja, best $75 purchase I've made other than beer LOL
« Last Edit: January 13, 2020, 04:54:15 PM by JeffH »
Offline JeffH
  • Ol skool jeeper
« Reply #3 on: January 19, 2020, 03:00:40 PM »
Spooled up the 150' 5/16 that came on the winch when purchased, I swapped ends and cut off about 6' to remove a kink and frayed area. Been researching a heavy duty continous duty solenoid to replace the blade switch that powers the winch through the 3rd push pull cable.  I ordered a 500 amp NVX solenoid and went to Napa for the other two control cables and a push button switch to power the switch when needed. Still need the battery cables to supply power, going to use 2/0 sized cables. Winch operates great with only a jumper cable installed on motor to spool the cable.
« Reply #4 on: January 20, 2020, 10:24:58 AM »
Looks like the drum easily handles 150" of the 5/16" cable.
Offline tow hook
« Reply #5 on: February 12, 2020, 10:25:48 AM »
awesome, i have bellview / warn ( model 6000) as well, it has the red/metal tag must be newer then yours. do you know the years they were made ? i've been trying to date mine for a while.
« Last Edit: February 12, 2020, 10:28:46 AM by tow hook »
Offline JeffH
  • Ol skool jeeper
« Reply #6 on: March 08, 2020, 07:16:41 AM »
Sorry for the delay, I do not have any production numbers or dates. I am always looking and lurking on a bunch of forums for more info. I do know that Warn bought Belleview MFG then offered the same winch for sale with their tags model numbers on it.
