Author Topic: T-98 or T-18 4 speed transmission swap  (Read 2702 times)
Offline specialty
  • 1952 CJ3A
« on: July 21, 2016, 03:50:16 PM »
I can get this transmission pretty cheap and was wondering if it can be put into a cj3a. The owner says it a bolt up except for a new pilot bearing for the shaft to line up. Has anyone ever done this swap? 1st and reverse are granny gears and 2-4th are synchronized. A 4 speed sounds nice.
Offline johnrb3b
    • Jeeps and stuff
Re: T-98 or T-18 4 speed transmission swap
« Reply #1 on: July 22, 2016, 11:02:45 AM »
Go to Herm the Overdrive Guy's site
He has a bunch of info on various transmissions and what it takes to put them in various Jeeps
Offline specialty
  • 1952 CJ3A
« Reply #2 on: July 23, 2016, 08:29:22 AM »
I have been doing a little checking and it looks like more trouble than whats it's
worth.
Offline Lee
  • Will-is enthousiast
« Reply #3 on: August 19, 2016, 10:20:35 PM »
Unless your rock crawling you really do not need it. It will not bolt up on either end unless this was from a real 4 cyl, 4 speed cj5. With adapters it can be done, and extensive floor mods, crossmember alterations, driveshaft shortening/lengthening.
Lee ;)
