Author Topic: Distributor  (Read 2383 times)
Offline CJTHREEA
Distributor
« on: June 20, 2016, 09:12:24 PM »
I am fixing an old Willys - I'm sure most of you can understand that I'm not 100% sure of what parts should stay and which parts should go.
Is there are good way to identify my distributor - and whether or not it has been converted to 12V or not?
Here are some pictures:
Can anyone help?
Re: Distributor
« Reply #1 on: June 20, 2016, 09:27:16 PM »
Welcome.
I can tell you that the distributor is original, but no way to tell what voltage you have based on these photos.  You may be able to find a part number or a voltage marking on your coil or condenser.   Pull the rotor and dust cap to locate the condenser.
Offline CJPilot
  • Shade Tree Mechanic
Re: Distributor
« Reply #2 on: June 20, 2016, 10:02:23 PM »
You could look at a couple of bulbs to see what voltage the Jeep was set up for.
Offline elawson
Re: Distributor
« Reply #3 on: June 20, 2016, 11:03:00 PM »
The distributor itself (including the points and condenser) is one of the things that stays the same for 6V or 12V.
The exact model number of the distributor--so you can get points and condenser--I can't tell
Re: Distributor
« Reply #4 on: June 20, 2016, 11:27:38 PM »
The distributor is an "IAD 4008".
