My Willys 3A and 3B Community
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
News:
Welcome everyone from the CJ3B!
Willys is a big family.
Home
Help
Search
Downloads
Gallery
Login
Register
3A, 3B, DJ Technical Knowledge Base
"Original"-- Technical Questions, Answers, Observations
Do I need to resurface this flywheel?
« previous
next »
Reply
Print
Pages: [
1
Go Down
Author
Topic: Do I need to resurface this flywheel? (Read 3019 times)
Ryan_M
Flatfender Master
on:
January 13, 2016, 06:58:29 PM »
This is the flywheel from the PE-95. I popped the 97 tooth ring gear off tonight and will install a 124 tooth ring gear as part of the intended genset to red 3A motor swap.
The PE-95 has no clutch so there is no wear to the flywheel. There is light rust and discoloration. Can I run it as-is or should it be resurfaced? I've had a flywheel resurfaced before but am not sure how critical it is or how bad one needs to get before it is required. I never resurfaced the flywheel on the gray 3A and it seems fine.
[/URL]
Logged
Flatfender Master
Re: Do I need to resurface this flywheel?
Reply #1 on:
January 13, 2016, 08:22:57 PM »
I'd clean it up with some sandpaper and then evaluate it. If it is flat it should work fine.
Last Edit: January 14, 2016, 09:11:36 PM by Bob_W
Logged
Ryan_289
Willys Fan
Still Plays With Jeeps
Reply #2 on:
January 14, 2016, 01:23:40 PM »
I would resurface it if it were mine. Around here its not very expensive to have it done.
Logged
Carls_jeep
Flatfender Master
Reply #3 on:
January 18, 2016, 09:54:28 AM »
If you have an orbital sander or can borrow one use 80 grit paper on it and buff it up. Your flywheel doesn't need resurfacing at all, just a good cleaning.
Logged
Mike S
Willys Fan
CJ2A SN CJ2A114542
Reply #4 on:
January 26, 2016, 03:14:48 AM »
Usually, when new clutch is installed the shop will resurface the fly wheel. But it is only really needed if t is glazed, rough, or rusted.
Logged
Life is short
Quit your job
Turn off the TV
Go outside and play
Reply
Print
Pages: [
1
Go Up
« previous
next »
