My Willys 3A and 3B Community
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
News:
Welcome everyone from the CJ3B!
Willys is a big family.
Home
Help
Search
Downloads
Gallery
Login
Register
3A, 3B, DJ Technical Knowledge Base
"Original"-- Technical Questions, Answers, Observations
Alternator Mounting Bracket
« previous
next »
Reply
Print
Pages: [
1
Go Down
Author
Topic: Alternator Mounting Bracket (Read 3115 times)
Austin
Flatfender Enthusiast
Still Plays With Jeeps
on:
October 17, 2015, 02:01:01 PM »
I am trying to figure out how this bracket attaches to my motor and how it holds the alternator on. Everything else is looking good.
Logged
Austin
Re: Alternator Mounting Bracket
Reply #1 on:
October 17, 2015, 02:02:14 PM »
Here is the bracket
Logged
athawk11
SMF Administrator
Flatfender Master
1949 CJ3A
Reply #2 on:
October 17, 2015, 07:19:41 PM »
Hope this helps...
Logged
athawk11
SMF Administrator
Flatfender Master
1949 CJ3A
Reply #3 on:
October 17, 2015, 07:22:00 PM »
I will add...This bracket is for a stock generator. If you're using an alternator, you'll need a different set up.
Logged
aboyandhisdog
Flatfender Master
Reply #4 on:
October 17, 2015, 07:33:37 PM »
Ha - I had to discover all of this too when I converted to an alternator. You'll need a pulley for the wide belt:
http://www.ebay.com/itm/361171729310?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
and then you need the new alternator bracket which will replace what you have: http://www.ebay.com/itm/201282063943?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Of course I'm assuming you have a stock 3A set up. Good luck - you will get there! BTW...be advised you will need to research how best to wire it in. I had a volt meter already so just ran the field wire to the switch and then a wire to the volt meter. If you plan to keep your ammeter, the wiring is different. I much prefer a voltmeter but it is up to you. I bought the Delco 3 wire alternator. I don't know much about the 1 wire alt.
Logged
Austin
Reply #5 on:
October 18, 2015, 08:20:31 AM »
Somehow that bracket was used on my 3a go mount the alternator. I just can't figure out how they had it set up. It looks very similar to those brackets that aboyandhisdog posted. I can't imagine that I am missing something.
Logged
aboyandhisdog
Flatfender Master
Reply #6 on:
October 18, 2015, 11:22:24 AM »
Austin, you do have the rod and nuts that go through the bracket and alternator (generator) right? Tim's photo is great but doesn't show the rod. Could you be missing that?
Logged
Austin
Reply #7 on:
October 19, 2015, 07:25:00 AM »
I figured it out. I ended up making a bracket. I will post a picture later on this morning.
Logged
Reply
Print
Pages: [
1
Go Up
« previous
next »
