Author Topic: Help! 51 CJ3A  (Read 109281 times)
Re: Help! 51 CJ3A
« Reply #225 on: April 10, 2015, 10:20:56 PM »
Don't give in.  The cable can be adjusted.  The cable, fulcrum and fork can all be replaced without removing the engine.  It would be a little tricky because of poor access, but it is possible.
Offline SSG T
  • Hooah
Re: Help! 51 CJ3A
« Reply #226 on: April 10, 2015, 10:21:06 PM »
I can't see into that area without dropping the transmission I also can't get to that cable with a wrench
« Last Edit: April 10, 2015, 10:22:08 PM by Taber12112 »
Re: Help! 51 CJ3A
« Reply #227 on: April 10, 2015, 10:22:47 PM »
Barney says...
One thing at a time...
Tighten the cable....
Re: Help! 51 CJ3A
« Reply #228 on: April 10, 2015, 10:27:03 PM »
I have an adjustable mirror on a stick.  Pretty handle in areas like this.
If you pull the small pin out of the clevis, your cable will flop down and allow you get a wrench on it.
Re: Help! 51 CJ3A
« Reply #229 on: April 10, 2015, 10:30:51 PM »
Offline SSG T
  • Hooah
Re: Help! 51 CJ3A
« Reply #230 on: April 10, 2015, 11:07:22 PM »
Its also now spitting oil out of #1 spark plug
Offline SSG T
  • Hooah
Re: Help! 51 CJ3A
« Reply #231 on: April 10, 2015, 11:10:14 PM »
I don't get how it worked fine before I pulled the motor tho as well
Offline SSG T
  • Hooah
Re: Help! 51 CJ3A
« Reply #232 on: April 10, 2015, 11:14:47 PM »
Hawk I tried that and the damn pin broke off and I can get it out
Re: Help! 51 CJ3A
« Reply #233 on: April 10, 2015, 11:54:27 PM »
You can do it....you got it timed and running... That was a major milestone!
Find a small punch or drift or even a nail and push it out......or grab the other end with pliers or side cutters and pull it out.....I know it's tight in there.....
Re: Help! 51 CJ3A
« Reply #234 on: April 11, 2015, 12:04:03 AM »
SSG,
You are pretty rusty down there.  Drill it out, then pick up a new pin.  You could shoot a little PB Blaster or your favorite penetrating fluid on some of those parts.  It will help when trying to break stuff free.  This type of stuff happens to all of us.  If you get a chance,  check out 1955CJ-5s thread in the project section.  It's called...To Rusty To Save? Lots of good stuff and many challenges that he works through.  It may show you...you're not alone.
We all get frustrated with these things. Sometimes you just need to step back from the grind.  Relax a while, and realize...this is suppose to be a fun passtime.  Then head back out and tackle each task with conviction.
Offline SSG T
  • Hooah
Re: Help! 51 CJ3A
« Reply #235 on: April 11, 2015, 01:41:16 AM »
Thanks guys. I'll give it another shot tomorrow or the next day. Got a friend that cab have this thing done and running in hours but he unfortunately lost his house last year to a house fire while his wife was deployed. He's almost done rebuilding and will have time to help. I won't sell her till he goes through it.
Offline dat
Re: Help! 51 CJ3A
« Reply #236 on: April 11, 2015, 09:44:37 AM »
This sucks. I'm about to drop it off somewhere get it running and put a for sale sign on it
don't give up, you're still making progress even if you don't think so,   but if you're selling, How cheap ??   ;)
Offline SSG T
  • Hooah
Re: Help! 51 CJ3A
« Reply #237 on: April 11, 2015, 12:19:18 PM »
Haha body is shot on this thing so its going to be a lose either way
Offline dat
Re: Help! 51 CJ3A
« Reply #238 on: April 11, 2015, 12:27:05 PM »
but fun, the body on mine is pretty much junk, but once I get all the pieces put back together, mechanically it'll be a fun ride again, something that I never minded if I bounced off a tree and kept on going.    now years down the road if I ever do a body restore, that would change.
cheaper than one of those big razors or ranger and a lot more classy
Offline SSG T
  • Hooah
Re: Help! 51 CJ3A
« Reply #239 on: April 11, 2015, 03:12:05 PM »
Exactly. They are the original side by side!
