Author Topic: How do the Donaldson air filters work?  (Read 7905 times)
« on: July 24, 2014, 11:52:26 PM »
It's been a while since I serviced my air filter, but I have always wondered how, exactly, do these things work?  I have the "FGA Oil Washed Air Cleaner" maintenance sheet, but it doesn't go into just how it works.  It talks about how it "condenses oil from the airstream" but I am trying to understand just what  that means.  Does anyone know?  Gunslinger...?
Re: How do the Donaldson air filters work?
« Reply #1 on: July 25, 2014, 12:10:04 AM »
They basically work in that they rely on the quick changing in air flow direction.� As the air comes in, it heads downward toward the oil sump, then the air turns 180*.� With the dirt having the downward direction velocity and more weight than the air, it tends to keep going down and hits and sticks to the oil.
Right guys?
« Last Edit: July 25, 2014, 12:10:51 AM by bretto »
« Reply #2 on: July 25, 2014, 05:17:14 AM »
Your are exactly right, Bretto. 8-)
« Reply #3 on: July 25, 2014, 05:58:57 AM »
For the second time this week I'll contribute an informative link from Bob W's site. Here's a solid run-down on how these filters work:
http://www.cj3a.info/tech/aircleaner.html
Pretty much how Bretto described it with a little more detail. Good stuff.
« Last Edit: July 25, 2014, 06:00:24 AM by Ryan_M »
« Reply #4 on: July 25, 2014, 03:16:05 PM »
Yup, that is a really good tutorial on air cleaners and how they work.  One thing that you should remember is that the Air Cleaner on the Willys is made with a non-removable screen, the service instructions for the FGA I believe reference a removable screen.  If you do want to clean the screen, flushing with kerosene is still a good method, just let it sit for a while to drain before you re-install.  As for the author of that article, I know he interviewed several Donaldson Engineers in order to develop it, in fact a Donaldson Product Manager reviewed that article for accuracy as well.   Yeh it was me....I sell filters for Donaldson.
« Reply #5 on: July 25, 2014, 03:24:55 PM »
I knew there was a Donaldson guy rattling around the forums but I forgot it was you Gunslinger. That helps explain your recent European business trip as well. I was curious what you were up to over there, besides guzzling wine on the company credit card  ;D
« Reply #6 on: July 25, 2014, 04:54:59 PM »
Thanks everybody.  I guess I need to start going to Bob's site first from now on.  How does the screen become treated with oil?  Just from driving, or do we need to oil it upon assembly?
« Reply #7 on: July 25, 2014, 06:04:25 PM »
Ryan ... ;D ;D ;D
Aboyandhis dog,
Just fill the oil cup to the prescribed level when you put it back together, as the engine compartment heats up the oil becomes less viscous and will splash up on the screen, oil vapors will also re-coalesce on the screen as well.  The screen then traps dirt in the oil and contains it from moving to the carb.  If you look into the oil cup, you will see that there are a couple of different chambers, these are for the purpose of containing the dirt sediment and keeping the oil somewhat clear of debris.
One note of interest, in 1942 the Army was having all kinds of  trouble with engine dusting in North Africa.  Frank Donaldson was called to Washington along with a bunch of other experts to solve the problem.. result, the M4A Sherman was outfitted with a Donaldson Oil Bath Air cleaner very similar to the one on the Willys.  In about 1989 we designed and installed a self cleaning air cleaner for the M1A1 Abrams, in desert trials the service interval went from 20 miles to 200 miles. Boy they liked that!!!!  Now I can get you one of these if you like, they are just a little larger than your jeep, weigh a little more, are armour plated, and cost abotu $20,000, if you buy in bulk !!! :o :o
« Reply #8 on: July 26, 2014, 01:42:07 AM »
$20,000 really?  Got to love the way our government spends our money.
« Reply #9 on: July 26, 2014, 09:00:11 AM »
What the heck, its a 3 million dollar tank!!! If you do the math it may come out exactly right, $4,000 dollar jeep, $50.00 air cleaner, 3 million dollar jeep (with gun) $20K air cleaner!!!! ;D ;D
Offline Lee
  • Will-is enthousiast
« Reply #10 on: July 26, 2014, 11:06:06 PM »
HHHHHHMMMMMmmmmmmmmmm, so what's a Donaldson hammer cost the government ;D
Lee ;)
« Reply #11 on: July 27, 2014, 11:19:05 PM »
Gun, I think it is very impressive that you can make an air filter for a tank...I see those things operate on TV and the dust they kick up, and am amazed anything can filter that air.  I can see what a problem it would be to get clean air to them.
Back to the L134...seems the faster the engine is turning, the better the filtration.  Is there still good filtration at idle and low rpm's?  Just curious.
« Reply #12 on: July 28, 2014, 05:52:30 PM »
Boy and dog,
The way these are designed the air flow has very little to do with efficiency.  Remember gravity is the driving force at low air flows and inertia is the driving force at higher air flows.  The other thing to consider is the size of the dust.  Gasoline engines can take dust up to about 5 micron in diameter before any damage is done, diesels not so, they get hammered with 1 tablespoon of 2 micron dust, that will cost you a rebuild.
So at low air flow the heavy dust comes into the air cleaner; and there is not enough air flow to carry it around the corner to the wire mesh.  So it just drops out, at higher air flows the dust has so much momentum that the heavy particles are running like a Babe Ruth home run and smash into the oil bath where they get trapped.  The lighter stuff makes the corner but gets mixed up with the oil vapor and either attaches to the screen or takes on the weight of the oil and drops out.
Every filter uses several different filtration mechanisms in concert to make them work: sieving, impaction, gravi-metrical separation, and some others that I only remember at work. Air Cleaners are designed for a range of air flows which are designed to protect the engine at all of the flows it will see.  Some things to look at on your air cleaner are all of the different sizes and shapes, Perforated inlet at the fire wall, behind air cleaner at the firewall (tough place for dirt to get to, large inlet area slows down the air and the big ones don't get carried in). The 90 degree turn above the oil bath, (big ones can't make the turn) tortuous path through the screen, large body at the the screen, (slows down the air at high flow) in order to capture particles.   One other thing to remember, at very low air flows (Idle) your air flow is so low that it will have a hard time picking up the big 5 micron dust particles that cause damage.  Kind of like a vacuum cleaner with a plugged bag, no sucky no dirty !
When you look at the air cleaner remember that every aspect of it is designed with air and dirt in mind.  Imagine a river with a log in it, that log is dust, the air cleaners job is to separate the log from the river.  Pretty much the same thing.
I got windy, I apologize.
« Reply #13 on: July 29, 2014, 09:42:49 AM »
Gun,
Not to divert too far from topic, but I find this thread really interesting!  It seems the oil bath air filter does a very good job of cleaning the incoming air.  Why did the OEM's make the switch to paper filters?  Ease of assembly on the line?  Source of revenue after the sale (replacement filters)?  Better performance?  Oil vapor in the airstream causing problems with MAF sensors?  Fuel economy?  Space constraints in the engine bay?
This is the kind of weird, interesting info that sticks in my brain!
Offline johnrb3b
    • Jeeps and stuff
« Reply #14 on: July 29, 2014, 11:30:57 AM »
Hey no apologies needed.
I love this kind of in-depth, tech stuff.
Keep up the great flow of info.
And I second macrisel's questions. I'm curious about all those issues as well.
« Last Edit: July 29, 2014, 11:32:05 AM by johnrb3b »
