Author Topic: Starting  (Read 3217 times)
Offline Operation Overlord
Starting
« on: July 13, 2014, 04:54:29 AM »
How long does it take your Jeep to start? I have a 6 volt 3A that after sitting for a week or two takes a long time to crank up. I'm talking 3 to 4 cranking iterations of 5-10 seconds each, sometimes longer.�
I have a fresh Walcks Carter that I replaced recently hoping to fix the problem. Fuel pump is new too as is entire fuel system. Feels like fuel in carb is evaporating or draining while sitting. Or maybe it's normal. I don't know. I've only seen one other Willys start. That was a 12v 2a with electronic distributor. Fires up nearly instantly.� Oh, I static timed the engine using flywheel marks as well. Same result.
Re: Starting
« Reply #1 on: July 13, 2014, 05:31:18 AM »
Are you using the choke? If you don't use these jeeps on on a regular basis, yes the bowl will dry out.
Re: Starting
« Reply #2 on: July 13, 2014, 06:32:45 AM »
Yes, using choke.
Re: Starting
« Reply #3 on: July 13, 2014, 10:49:01 AM »
What I do is pump the accelerator four or five times, pull the choke out about half way or more if it's cold out, and it starts pretty quickly. Sometimes it will die or I'll need to pull the choke out further to keep it running. I push the choke back in a little at a time, but I have it all the way in as soon as possible, probably just a minute or two...
This would be for the first start of the day...a pump of the accelerator is usually all it needs after sitting for just a few hours...
it's a 6 volt system....stock points, coil etc..static timed like yours...
When it sat for a while over the winter it took more cranking to get it going...more like what you describe....
« Last Edit: July 13, 2014, 11:13:23 AM by 1955CJ-5 »
Re: Starting
« Reply #4 on: July 13, 2014, 12:23:26 PM »
Both of mine fire right up. Ted is still 6 volt and he starts immediately after hitting the foot starter. When he is cold, I have to pump the gas once. My '53 needs to be choked when cold then starts no problem after that.
Re: Starting
« Reply #5 on: July 13, 2014, 12:38:30 PM »
My jeep is lot like my son when he was 19, if he sat too long you had to choke him to get him moving, if he had only sat for a bit a little kick was all it took  ;D ;D ;D
Re: Starting
« Reply #6 on: July 13, 2014, 03:16:32 PM »
How does it sound when cranking?� If fairly slow, it could be an electrical issue verses a fuel issue...or a combination of both fuel and electrical.
6 volt systems need to have a fully charged battery, heavy "0" or "00" battery cables, and very clean grounds.� If the cranking is slow, it may take longer for the mechanical fuel pump to fill the supply lines and fuel bowl while working to replace the evaporated fuel.
Just another thing to consider.
Re: Starting
« Reply #7 on: July 13, 2014, 10:06:34 PM »
Well, sounds like i have some work yet. I want to get it to fire up much faster. I'll try and post a video of it starting in the next couple of days. See what y'all think.
