Author Topic: Radiator Assembly to Frame  (Read 1981 times)
« on: June 10, 2014, 05:10:58 PM »
On the bottom mounted radiator, were there rubber pads to fit between the radiator and frame? I can't remember if I took 2 pads off.
George
Re: Radiator Assembly to Frame
« Reply #1 on: June 10, 2014, 10:39:57 PM »
Hi George.� Good to see you back in the saddle.
There are pads on the bottom mount radiators.� The only Willys I have that still has the original pads is the '46 2A.� They appear to be a little thicker than 1/4", and are made of the same material as the tub mounts.�
For ODie and Whitey, I used the cut up side wall of an old ply tire.� I believe the idea is to cushion the radiator, and at the same time, center the fan on the radiator shroud.� Adjust the pad thickness to achieve this centering.
Hope this helps.
« Reply #2 on: June 11, 2014, 09:43:04 AM »
Thanks Tim,
This is very helpful information. I'm glad to be working on the 49 again!
George
