Author Topic: Jerry Can Mount  (Read 18731 times)
Offline Steve
  • First Project
Jerry Can Mount
« on: May 24, 2014, 07:15:08 PM »
At a junk store today looking at Jerry cans.  The guy had four crappy cans that were not usable, but one of the cans had a mount on the bottom. I bought it and little did I know that it appears to be an old military jeep Jerry can holder.  At the moment (picture) I am removing the paint. My question is where do folks usually attach this mount? If to the tailgate, do you use a backing plate? Thanks.
Steve
1950 CJ3A Mostly Stock
Re: Jerry Can Mount
« Reply #1 on: May 24, 2014, 09:01:24 PM »
Because I am on very tight trails I put the can mount and the spare tire in the rear bed of the Jeep. Trees can't rip them off there.
Offline gmcjr
Re: Jerry Can Mount
« Reply #2 on: May 24, 2014, 09:40:27 PM »
Good find!!
A lot of people mount then on the sides, and such, but here's what I did, I didn't use the tailgate anyways, and don't have to worry about knocking them off with trees.
It's about the same layout as a M38.
FYI,� My finger is only there to hide my plate number, and yes the spare is flat. That happened 30 min before I took the picture, lol!
The M38 tailgate has extra support built in, so yes, it does need backing.
I just used scrap angle iron to build this.
Hope this gives you some ideas!!!
« Last Edit: May 24, 2014, 09:50:04 PM by gmcjr »
Gary in N. Texas
51 CJ-3A (old Trusty)
52 Ford 8n (ugly duckling)
46Farmall B (old Rusty)
18 Wrangler Jk
Re: Jerry Can Mount
« Reply #3 on: May 24, 2014, 09:48:02 PM »
I was once told that Willys(or maybe aftermarket?) put out a reinforcement kit for the tailgate, so you could mount the can and tire back there...hard wood supports I was told..
Any one heard of this or seen it?
My CJ-5 had a can mount on the right side between the passenger cutout and the front fender....terrible place for a gas can!
Offline Steve
  • First Project
Re: Jerry Can Mount
« Reply #4 on: May 24, 2014, 10:52:52 PM »
Thanks for the ideas and pictures.
Steve
Re: Jerry Can Mount
« Reply #5 on: May 25, 2014, 07:17:46 AM »
Here's a link and a pic from the 3B page. It's a real high tech piece of equipment.
http://cj3b.info/Tech/TailgateSpare.html
Re: Jerry Can Mount
« Reply #6 on: May 25, 2014, 07:26:12 AM »
Hey GMC -
What are you using for a spare tire bracket? Is it just the 3A style one or do you have the M38 one with the bottom support as well? I was thinking of adding a 3A one to my M38 tailgate but wasn't sure if it would hold up. I'm thinking there must have been a reason the extra support was added to the M38 ones.
« Last Edit: May 25, 2014, 07:27:00 AM by Ryan_M »
Re: Jerry Can Mount
« Reply #7 on: May 25, 2014, 07:28:11 AM »
Jerry can mount that bolts to the draw bar is by far the best solution... Removable so you can still use the tailgate.
Re: Jerry Can Mount
« Reply #8 on: May 25, 2014, 07:30:41 AM »
Or build your own swing away spare tire carrier.
Offline gmcjr
Re: Jerry Can Mount
« Reply #9 on: May 25, 2014, 09:25:17 AM »
Hey GMC -
A reproduction M38 one.  :)
« Last Edit: May 25, 2014, 09:25:51 AM by gmcjr »
Gary in N. Texas
18 Wrangler Jk
Re: Jerry Can Mount
« Reply #10 on: May 25, 2014, 11:14:17 AM »
This a photo of my Jeep ready for the trails. Fuel on drivers side, spare tire on passenger side, long spade on floor with stake to drive in ground to pull with, container on bottom full of pulling straps, container on top contains maps and other necessaries, tool bag and lug wrench, jack mounted behind spare tire.
If you look close there is a warning decal on the dash to my passenger. It says, Hang On, I Want To Try Something.
NOTICE: I didn't cover my license plate because I am proud of both of them and see no reason to deny anyone the pleasure of seeing them.
« Last Edit: May 25, 2014, 05:58:40 PM by Carlsjeep »
Re: Jerry Can Mount
« Reply #11 on: May 25, 2014, 10:54:08 PM »
I duplicated the inner reinforcement of an M38 using T shaped iron for the gas can mount. (Cut up an old garage door opener rail)
I used oak to support the tire carrier.
Offline Jesse
Re: Jerry Can Mount
« Reply #12 on: June 02, 2014, 12:20:08 AM »
Athawk, I have always been jealous of your rig! so clean and awesome.
I second the swing out carrier, its one of my favorite parts on the jeep
