Author Topic: Seat Belt Anchors?  (Read 11877 times)
Seat Belt Anchors?
« on: December 13, 2013, 10:55:32 PM »
I'm thinking that I will install seat belts. I found a set of aircraft style quick release 1 3/4" belts that were meant to clip into eye bolts. So, That is probably what I'll use, but I thought I'd see what others have done.
I'm not sure where the anchors ought to be in terms of having the belt at an effective angle..
Re: Seat Belt Anchors?
« Reply #1 on: December 14, 2013, 05:37:24 AM »
[size=8]Obviously I can't see them, but are you sure eyebolts? All I am aware of are latch plates with a four-bolt pattern and either a recessed rod or a welded-on plate with a hole in it for the latch.[/size]
« Reply #2 on: December 14, 2013, 09:03:28 AM »
These are what I used on my '53. I bolted mine through the hat channels next to the seats that come down from the side and on to the rear fender well and then other ends are bolted on by one bolt which goes through the side of the toolbox near the rear floor riser.
http://www.ebay.com/itm/BLACK-SEAT-BELT-SET-NEW-60-CHROME-BUCKLE-BELTS-W-HARDWARE-SECURES-2-PASSENGERS-/291001545503?pt=Vintage_Car_Truck_Parts_Accessories&hash=item43c10b331f
« Last Edit: December 14, 2013, 09:04:28 AM by garage_gnome »
« Reply #3 on: December 14, 2013, 11:01:14 AM »
I expect that when they were mounted in whatever vehicle they came out of that they clipped to the seat frame.� The tag reads:
"BELT: Aircraft, Safety, Lap, Troop, Type MC1A" With plenty of numbers.
I think ring bolts is what I meant to say....
I agree about going through the side brace on the outboard of the seats....
« Last Edit: December 14, 2013, 11:02:41 AM by 1955CJ-5 »
« Reply #4 on: December 14, 2013, 12:17:34 PM »
Here is what I'm talking about.
« Reply #5 on: December 14, 2013, 12:31:01 PM »
Well, those brackets would be perfect...
But where do I find them?
I would really like to use something that is more appropriate than a hardware store ring bolt...I was going to try some footmen loops but they are too small, and I have a frame tie-down footman but it is way too large....
« Reply #6 on: December 14, 2013, 12:35:04 PM »
http://www.summitracing.com/parts/gfr-109l/overview/
Summit has a lot of seat belt stuff...take a look around.
« Reply #7 on: December 14, 2013, 12:47:07 PM »
That is what I had in mind.....Thanks Bill...
But I'm still open to options....
« Last Edit: December 14, 2013, 12:47:23 PM by 1955CJ-5 »
Offline SteveW
« Reply #8 on: December 14, 2013, 04:43:09 PM »
I have some 60's era lap belts and put one side on the slope of the wheel housing and the other about 4.5 inches back on the deck with 3/8 bolts through and large washers on the back side and nylock nuts on them.
Offline Matto
« Reply #9 on: December 14, 2013, 04:51:31 PM »
These guys have a pretty good selection, I bought belts for my 3B here.
https://www.seatbeltsplus.com/mm5/merchant.mvc?Session_ID=1558663a6356873596463aacf303fecc&
« Reply #10 on: December 14, 2013, 08:42:11 PM »
Well, thanks for the links...there sure are a lot of options out there...
I ordered four of the anchors from Summit racing that F Bill pointed out...
Offline stony
« Reply #11 on: December 14, 2013, 09:49:03 PM »
CJ-5's aircraft belts sure bring back memories.� Put the exact same belts in my '56' CJ-5 back in '70'.  Got em at the Elmendorf base surplus store.� Gotta see if I can get them back from my nephew.� Probably take a whole bottle of *.
« Last Edit: December 14, 2013, 09:49:52 PM by stonyloam »
Terry
« Reply #12 on: December 14, 2013, 10:33:33 PM »
I'm always learning something on this forum....
Never heard of *.....
It sounds like a good plan, and he may even offer a sip...
Offline stony
« Reply #13 on: December 14, 2013, 11:11:34 PM »
George *, Tennessee sour mash, even though my current fav is Larceny.
Terry
Offline SteveW
« Reply #14 on: December 16, 2013, 05:45:05 PM »
Here is my set up. Belts are actually 1983 dated.
