Author Topic: Spicer for Bendex  (Read 4820 times)
Offline Steve
  • First Project
Spicer for Bendex
« on: December 17, 2013, 12:49:45 AM »
The deconstructin continues and the list of items that need replacing continues to grow. The latest is the original Bendex axels. I have ordered replacement Spicer axels an and am wondering what things I need to watch out for when making the swap. Also, the axels I removed were coated with grease, should I coat the new axels prior to insertion.
Steve
1950 CJ3A Mostly Stock
Re: Spicer for Bendex
« Reply #1 on: December 17, 2013, 06:08:40 AM »
I would coat in grease and there is nothing to watch out for. The Spicers should just slide right back in. What was wrong with the old bendix joints?
« Reply #2 on: December 17, 2013, 09:01:34 AM »
I think you will need to check if the bushing spindle is required.
Saw this on walck's:
http://walcks4wd.com/bushing-spindle-rzeppa-and-spi.html
And there is also a snap ring:
http://walcks4wd.com/snap-ring-axle-spicer.html
There is bushing for bendix joint itself. You might need to remove those.
http://walcks4wd.com/bushing-spindle.html
http://walcks4wd.com/outer-axle-tube-bushing-bendix.html
http://walcks4wd.com/thrust-washer-front-axle-shaft.html
I never do this myself but I do believe that it's not a straight forward replacement. If it was me, I would give a call to Carl Walck and discuss about it.
There is also a screw on each side of the axle to adjust the maximum rotation angle of the steering.
We have three different kind of joint with three different rotation angle...
« Reply #3 on: December 17, 2013, 10:39:13 AM »
I have Bendix joints. But, the spindles have the shouldered bushing. There is a thread about this somewhere...if you have the shouldered bushings and they are in good shape then you are good to go...I'll look for that thread....
« Reply #4 on: December 17, 2013, 10:41:18 AM »
Offline Steve
  • First Project
« Reply #5 on: December 17, 2013, 11:03:49 AM »
Thanks for the replies; I am flying by the seat of my pants on this particular project. It is going to take me a bit of looking and thinking to figure out where the bushing is supposed to go (I ordered bushings with the axles).
I didn't notice the screws on the side of the axle for adjusting the rotation. Does anyone know the correct angle for the Spicer axle?
I have to replace the old axles because the balls have dug huge groves into the race. Everything else in the steering knuckle was trashed, so it's no surprise that the axles would be shot as well.
« Reply #6 on: December 17, 2013, 11:30:38 AM »
If you have the Service Manual reprint the steering angles are in section O-14a..
I'm not sure how to check them though, without taking the whole jeep to an alignment shop...
Offline Steve
  • First Project
« Reply #7 on: December 17, 2013, 04:18:04 PM »
I do have the Service Manual reprint. Thanks for the tip. Much to learn....
« Reply #8 on: December 17, 2013, 04:59:01 PM »
I am always surprised by how much info is in that manual....
« Reply #9 on: December 17, 2013, 09:11:18 PM »
Vernco.com has a cool way to measure and adjust the steering stops if you dare to visit the site.....
http://www.vernco.com/FrontAxle/id373_turn_limit_with_seal.htm
Offline Steve
  • First Project
« Reply #10 on: December 17, 2013, 09:39:42 PM »
Wow, lots of details and I already used a punch to remove the kingpin bearing races  :-X
An interesting note is that although I have the Bendex axle, I also have the bushing that works for the Spicer...at least I think so.
« Reply #11 on: December 18, 2013, 06:31:24 AM »
Not all Bendix shafts are the same, later ones use the shouldered bushings.
